ADVICE::Fuel Injection Cleaner
PerfectCreature
My local Sears has a sale on their fuel injection cleaner system that they have going on. They say it increases throttle response, gas mileage and such.
Has anyone had this done by them, or had a similar service with good results...
Would I just be wasting my money by doing this?
Thanks for the advice.
Receiver
Harman Kardon HK 3490
Speakers
Polk Audio Monitor 50s
Subwoofer
Klipsch KSW-100
Cables
AudioQuest Rocket 33s 10ft
AudioQuest Optilink1 2m
AudioQuest Alpha-Snake 25ft Interconnect
AudioQuest HDMI-1 2m
Alienware X51 R2
PS4
Samsung Smart TV 40" 1080p 3D
Speakers
Subwoofer
Klipsch KSW-100
Cables
Alienware X51 R2
PS4
Post edited by PerfectCreature on
How old is your car? How many miles etc. Most likely you do not need it done.Living Room Rig:D
Rotel RSP-1069/Rotel RMB-1095/Rotel-1072/Polk lsI15's W/modded xoverW/DBsubs/Polk LsiC/lsI7's/Klipsch sub-12"the weak link"/DLP Mitsubishi 65"
Xbox360/PS3/WII
M.Br. setup:)
Emotiva MMC-1/Rotel RMB-1075/Polk BlackStone TL350's/Velodyne SPL1000/Samsung 51" Plasma
Computer Rig:
Rotel RB1050/Tannoy DC4's/Klipsch RW-10d/ImodIpod/HK AVR230 for now....
Headphones-Ultrasone-HFI780's w/LittleDot MK Vamp Portables Panasonic HJE-900's -
1995, 125,798 miles.
It is also having its transmission fluid changed with a brand new filter as well.
They said they will give a double discount if I do both....
Just wondering if the sears one is a good one...
They say its a three part system.Receiver
Speakers
Subwoofer
Klipsch KSW-100
Cables
Alienware X51 R2
PS4
Samsung Smart TV 40" 1080p 3D -
Well i'm sure you have some crude in there but hard to say if you will see a difference or not.
If the price seems like a good deal go for it.
Myself i run a can of SeaFoam thru the tank every so often to keep things clean.Living Room Rig:D
Xbox360/PS3/WII
M.Br. setup:)
Computer Rig:
I have never heard of SeaFOam....
We have stuff like marvel mystery oil and Lucas oil, Pennzoil and a few other brands that make their additive fuel cleaners, I've tried those before used Lucas oil a couple times didn't really notice anything.
Was just wondering if you know around 55, 60 bucks would be worth seeing if it does make a difference.
Was more or less hoping someone on here had had it done by sears and could give me a first hand account on what it did for them since I have yet to find a single review on their service...Receiver
Speakers
Subwoofer
Klipsch KSW-100
Cables
Alienware X51 R2
PS4
TouchOfEvil wrote: »Myself i run a can of SeaFoam thru the tank every so often to keep things clean.
+1. I run half through the throttle body and the rest through the tank. -
How do you run it through the throttle body?
I'm not much of an extended fix-ya guy when it comes to mechanical stuff. I can do electrical but...eh... not so much mechanics.Receiver
Speakers
Subwoofer
Klipsch KSW-100
Cables
Alienware X51 R2
PS4
http://www.lt1engine.com/tech/how-to-seafoam-your-car-clean-carbon-buildup/
I did it through the brake booster line on a 2000 Accord.
http://www.youtube.com/watch?v=Za-b4wufsvg -
Hmm. That seafoam stuff looks like quite a bit of work.
You saw results and such I assume?Receiver
Speakers
Subwoofer
Klipsch KSW-100
Cables
Alienware X51 R2
PS4
Just pick up a bottle of Techron at the auto parts store, it's about $10."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
The Accord was idling rough and eventually the check engine light came on with a P0420 code: Catalyst System Efficiency Below Threshold. I was thinking new catalytic converter and/or O2 sensors but decided to do the Seafoam first. Worked like a charm. Tons of smoke though. Yeah, it'll eat up 30 to 45 minutes of your time. The Accord was at around 135,000 miles IIRC.
As with anything on the 'Net, if you're not comfortable with the information you see, take the car in. Perhaps someone else will add their experience.
Good luck.
Edit: Forgot to mention. I tried to clean out the system with Lucas Upper Cylinder Lubricant "with Inject Cleaners and Fuel Conditioners" first but it didn't solve the error light nor the rough idling. I did the Seafoam a week after I tried Lucas. -
I may look into the seafoam stuff.
What about techron...how does that compare to the seafoam?
How much would either cost (roughly) to pick up all the stuff I would need...anyone know estimates?
Has anyone used the Lucas fuel injector cleaner?
My cousin swears by it ....just curious.Receiver
Speakers
Subwoofer
Klipsch KSW-100
Cables
Alienware X51 R2
PS4
I was editing my post#11 to add comments about Lucas when you edit your post.
I bought the $10 bottle of Lucas but it didn't solve my problem but I did have a big enough problem for the check engine light to come on. I still use Lucas on both our cars but there's a new bottle of Seafoam sitting next to it for backup. -
Seafoam's the best. I clean my car's intake once a year with it.SRT For Life; SDA Forever!
The SRT SEISMIC System:
Four main satellite speakers, six powered subs, two dedicated for LFE channel, two center speakers for over/under screen placement and three Control Centers. Amaze your friends, terrorize your neighbors, seize the audio bragging rights for your state. Go ahead, buy it; you only go around once. -
I should add that I'm a shade tree mechanic with Craftsman tools. There's a lot of talent on this forum so maybe someone with Snap On Tools other than a poser like me will add additional insight this weekend.
Well this is what the sears fuel system cleaning says
Description: Fuel System Cleaning is a multi-step service helps clean the fuel system and internal combustion chamber. The procedure involves using a chemical to clean the combustion chamber and related parts, an oil additive, a fuel additive, and cleaning of the throttle body when applicable. This service restores engine performance by improving acceleration, helps eliminate rough idle and hesitation, reduces exhaust emissions, and prolongs the life of most fuel injector systems.
So really that would be about what I would be doing with the SeaFoam (Aside from smoking my block up and maybe getting the fire trucks called, I live in a small town heh)
Maybe have a mechanic to the seafoam and then after just use the lucas oil
Or would I be better off doing the sears ones and then the lucas oil?
Opinions?
Thanks.Receiver
Speakers
Subwoofer
Klipsch KSW-100
Cables
Alienware X51 R2
PS4
I only use the Slick 50 stuff for about $10-$12 bottle. Only fill the tank 1/4-1/3 full so you don't pull all the crude off the top of the gas tank thru the injectors.
Yeah I have seen walmart with the slick 50 but I mean there are so many...and so many people boasting so many products...
Hmm. Decisions.Receiver
Speakers
Subwoofer
Klipsch KSW-100
Cables
Alienware X51 R2
PS4
Parasound C1, T3, HCA-3500, HCA-2205A, P/DD1550, Pioneer DV-79avi, Oppo BDP-83, WD Media Server W/HDD,
Dynaudio Contour 3.3, Dynaudio Contour T2.1, Polk OWM3, Polk DSW micropro 1000 (x2),
Pioneer Kuro 50" Plasma, Phillips Pronto Control w/Niles HT-MSU. -
Once a month I run a tank of premium, no problems.Polk Audio Surround Bar 360
Mirage PS-12
LG BDP-550
Motorola HD FIOS DVR
Panasonic 42" Plasma
XBOX 360[/SIZE]
Office stuff
Allied 395 receiver
Pioneer CDP PD-M430
RT8t's & Wharfedale Diamond II's[/SIZE]
Life is one grand, sweet song, so start the music. ~Ronald Reagan -
I am not sure that a match would give me the results that will last :PReceiver
Speakers
Subwoofer
Klipsch KSW-100
Cables
Alienware X51 R2
PS4
PerfectCreature wrote: »I am not sure that a match would give me the results that will last :P
BG 44K at Advanced auto parts. it works period. -
PerfectCreature wrote: »Hmm. That seafoam stuff looks like quite a bit of work.
How does pouring a can of it into your gas tank, sound like alot of work?
The second can is for cleaning the internals and oil, you just want to clean the injectors, yes?HT SYSTEM-
lsi 9's -
Seafoam is da'bomb! I've been using it to keep the dirtbikes, ATV's, power equipment, etc. at the farm running good for many years. I've been using Techron fuel injector cleaner in the vehicles, but probably should switch over to Seafoam.DKG999
Music System: Magnepan 1.6QR, SVS SB12+, ARC pre, Parasound HCA1500 vertically bi-amped, Jolida CDP, Pro-Ject RM5.1SE TT, Pro-Ject TubeBox SE phono pre, SBT, PS Audio DLIII DAC -
Wonder Pie is in order here perhaps?--Gary--
PerfectCreature wrote: »Well this is what the sears fuel system cleaning says
Opinions?
Thanks.
If you want to clean the fuel injection you can simply pour a can of seafoam into the gas tank and leave it be. It will do it's job. The thing from sears takes care of the fuel injection and cleans the internal engine parts. This should help smooth out your idle and such but the same thing can be done with the seafoam via the brake booster line. If you don't feel comfortable with doing though just let sears have at it.
Also stay away from the oil additives all together. If you want better protection go with a better oil in general like a full synthetic.
The oil additives are not good for the motor. Just do some searching around on the net and you can find out what it really does.Living Room Rig:D
Xbox360/PS3/WII
M.Br. setup:)
Computer Rig:
I have had great success with Seafoam where others that I have tried were a waste of moneyengtaz
Redline Fuel System cleaner works absolutely fantastic, better than Seafoam, IMO.
H9"Appreciation of audio is a completely subjective human experience. Measurements can provide a measure of insight, but are no substitute for human judgment. Why are we looking to reduce a subjective experience to objective criteria anyway? The subtleties of music and audio reproduction are for those who appreciate it. Differentiation by numbers is for those who do not".--Nelson Pass Pass Labs XA25 | EE Avant Pre | EE Mini Max Supreme DAC | MIT Shotgun S1 | Pangea AC14SE MKII | Legend L600 | BlueSound Node 3 - Tubes add soul! -
So, really just have a mechanic pour the seafoam in the break booster line, add a can to the gas tank and run it to about empty...then fill up?
Am I missing anything?Receiver
Speakers
Subwoofer
Klipsch KSW-100
Cables
Alienware X51 R2
PS4
I don't want wonder pie derailing another post since this one is rather important.
Thank.sReceiver
Speakers
Subwoofer
Klipsch KSW-100
Cables
Alienware X51 R2
PS4
1/2 in booster line 1/2 in oil. 1 full in tank.engtaz
