WaterWorld to The Rescue???
nooshinjohn
I could not believe it until I read it... Kevein Costner may have the means to assist in recovering oil in the gulf! This appears to NOT be a joke or a publicity stunt. I am stunned to say the least.:eek:
http://www.comcast.net/articles/entertainment-eonline/20100521/b182270/
<object width="555" height="457"><param name="movie" value="http://www.comcast.net/ve/1.0/1500400278/555/457/"></param><param name="wmode" value="transparent"></param><param name="allowScriptAccess" value="always"></param><param name="allowfullscreen" value="true"></param><embed src="http://www.comcast.net/ve/1.0/1500400278/555/457/" allowScriptAccess="always" allowfullscreen="true" width="555" height="457" type="application/x-shockwave-flash" wmode="transparent" pluginspage="http://www.macromedia.com/go/getflashplayer"></embed></object>
Post edited by nooshinjohn on
I have not seen that before. Wonder if it really works.Sunfire TGP, Sunfire Cinema Grand, Sunfire 300~2 (2), Sunfire True Sub (2),Carver ALS Platinum, Carver AL III, TFM-55, C-19, C-9, TX-8, SDA-490t, SDA-390t
I can't believe two days have gone by before a comment!:eek::p
While it pains me a bit for Mr Kostner to get uber-rich and remembered for this (I would rather he be remembered for his crappy movies:rolleyes:) I am glad that someone from LaLa Land has put his money where his mouth is and at least has made the attempt to make a difference.The Gear... Carver "Statement" Mono-blocks, Mcintosh C2300 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon 680d DSD
“When once a Republic is corrupted, there is no possibility of remedying any of the growing evils but by removing the corruption and restoring its lost principles; every other correction is either useless or a new evil.”— Thomas Jefferson -
thuffman03 wrote: »I have not seen that before. Wonder if it really works.
Don't see why it wouldn't. Centrifuges work on weight of substances in them. Oil is lighter than water and even if two or more substances are dissolved in a solution or even just suspended in each other, a centrifuge can be used to systematically separate a large majority of those substances from each other.
Under normal gravity, they may not separate. But under the heightened "gravity" that the G forces in a centrifuge puts on a solution, the different substances could easily be separated.
Another option is to use a still to distill the elements from each other. Oil has a much higher boiling point than sea water. However, it is inefficient, especially considering fuel sources and the cost vs. outcome. Also, adding heat to the oil/water solution will change chemical bonds and you might end up with something equally or worse so, more toxic than what you started with.
A centrifuge is much more efficient and doesn't necessarily change molecular structures. That way not only do you get the water out of the oil but you can recover the lost oil and package it up for refining.Expert Moron Extraordinaire
nooshinjohn wrote: »I can't believe two days have gone by before a comment!:eek::p
Who really cares if the man gets rich solving a problem that causes economic and environmental problems with a device that is both affordable and effective? You are going to sit there and be that shallow because you dislike the man as an actor and damn his project to failure over your own petty, shallow misgivings? That really speaks to your character.
And if you are going to insult the man, at least give Mr. Costner the common decent to spell his name correctly.
Personally, kudos to Mr. Costner for seeing a need, putting the funding in place HIMSELF to find someone smarter than him to put his ideas in action and then getting it out in the public view. Instead of standing on a pulpit in Hollywood ranting that someone should do something, he went and became that someone and did something. That speaks to his character too. If he makes a few bucks for his efforts then I'm glad to see it. He put the time, money and effort in to saving some very critical waterways and as an avid fisherman bent on keeping our coasts clean and healthy as well, the man has earned my respect for a long time to come.Expert Moron Extraordinaire
Yeah, why bash Costner for doing a good thing?
I say way to go, dude!"Wish I didn't know now what I didn't know then." Bob Seger -
Re-read the post John(correctly spelled I hope;)) I do point out that I am thankful he stepped up to the plate to make a difference rather than just claim moral superiority on the issue because he has a good intention. If all celebs were so bold as to do the same thing, the world could be a better place.:)
The healthy dose of sarcasm in the post is warranted by the fact that actors/actresses in general always seem to put themselves into such stories for their own publicity rather than actually doing anything to help. Mr. Costner gets a bit of respect from me for doing something completely unpredicted and changing the script.The Gear... Carver "Statement" Mono-blocks, Mcintosh C2300 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon 680d DSD
nooshinjohn wrote: »Re-read the post John(correctly spelled I hope;)) I do point out that I am thankful he stepped up to the plate to make a difference rather than just claim moral superiority on the issue because he has a good intention. If all celebs were so bold as to do the same thing, the world could be a better place.:)
The healthy dose of sarcasm in the post is warranted by the fact that actors/actresses in general always put themselves into such stories for their own publicity rather than actually doing anything to help. Mr. Costner gets a bit of respect from me for doing something completely unpredicted and changing the script.
Don't be foolish. You are trying to put a spin on a statement that you made. I wasn't the only one who had a poor reaction to it.
You stated:nooshinjohn wrote: »I can't believe two days have gone by before a comment!:eek::p
In which this statement drew the ire of others:nooshinjohn wrote: »I can't believe two days have gone by before a comment!:eek::p
Which, IMO, is heinous in it's arrogance and pettiness and totally over-shadows any good intentions this statement may have been able to cover up:nooshinjohn wrote: »I can't believe two days have gone by before a comment!:eek::p
You stuck your foot in your mouth yet again. Stop trying to back peddle and spin it. It's probably not easy to back-peddle with one foot stuck in your mouth anyway. If you mis-spoke then say so. Don't try to discredit me with your petty jabs over spelling. You spelled the man's name incorrectly while trashing him for a good thing. That's just not cool. Don't get all **** about it, just realize you made the mistake. You won't hesitate to jump on anyone about a mistake they may have made but you don't like it when others do it to you.Expert Moron Extraordinaire
Once again John, re-read the thread. As always, you seek to be combative and argumentative. I stated that I think his movies are not the best(Dances with Wolves/Field of Dreams excepted) but his actions should be commended. Nobody else has taken issue except for you, and as always, you take things to the extreme. Speeling was an oversite and I have punished my DysleXic fingers for it. My index finger will never look at a keyboard the same way again.;)
May I recommend learning how to appreciate sarcasm(as noted by the :rolleyes: emote), and a polite joke? (denoted by the )The Gear... Carver "Statement" Mono-blocks, Mcintosh C2300 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon 680d DSD
Geez! I think we are getting a little picky here aren't we. It appears to me that NJohn was be sarcastic and joking as exhibited by his smiley faces but on the serious note was commending Costner for not just being a Hollywood talking head. As exhibited here;
At least that the way I read it. -
I was listening to news radio on the way to lunch and they mentioned BP taking Costner's idea and trying it out on the oil spill. It clogged. "Scientists" are now trying to make modifications.
Furthermore, BP is testing 250 different ideas and is overwhelmed by the number of suggestions. Critics say they aren't listening. BP says they are and that they're also talking with their competitors for ideas on the cleanup. -
So...someone get me up to speed.
Does this leak mean the oceans are going to turn black now?"Dr Dunn admitted that his research could also be interpreted as evidence that women are shallower than men. He said: "Let's face it - there's evidence to support it."Best Buy is for people who don't know any better. Magnolia is for people who don't know any better and have more money to spend.
TV: SAMSUNG UN55B7000 55" 1080p LED HDTV
HTPC: Chromecast w/ Plex Media Server. Media streamed from Media Server. -
BP is buying Coster's machines!
WOOHOO! I hope they are a raving success!
http://www.cnn.com/2010/US/06/15/oil.disaster.costner/index.html?hpt=T1Expert Moron Extraordinaire
I could care less if a 5th grader came up with a solution. Kevin bought that patent awhile ago, not like he did it just for this spill. Innovative idea's is whats needed in many industries.Every little bit helps, there is no one solution to this problem. Saw an interesting stat today too. Deep water wells,around the globe, we have 14,000 of them ? If thats true, you have to admit, generally speaking, this particular situation doesn't happen often. Kudo's to Costner for putting his money where it could do some good. There have been many Hollywood types who pretty much detached themselves from that stigma to do good...Paul Newman comes to mind. That man set an example I hope Costner and others would follow.HT SYSTEM-
lsi 9's -
I'm with Joe...we need to chill a bit here. I can't see the video (China), but if it works..hey, do it! As for Hollywood....let's forget about their politics for a while. Not everyone there is liberal or conservative....Jeeesh. America, my country when are we going to actually listen to each other and work together? When the Democratic Party ceases to exist? Or when the Republican Party does?
Because I hate to say it. But a year away from American politics and Left vs. Right has been quite refreshing!
Now let's just fix the problem 'together', please?
I guess BP already tried the worlds largest bottle of Dry Gas?Ludicrous gibs!
This is good news, and suprizing that it has taken this long for some action.The Gear... Carver "Statement" Mono-blocks, Mcintosh C2300 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon 680d DSD
nooshinjohn wrote: »This is good news, and suprizing that it has taken this long for some action.
Yeah,warp speed, about as fast as the DMV.HT SYSTEM-
lsi 9's -
From an ABC News interview I read, Costner invested $20 million of his money to develop this device and was frustrated that neither the government nor any of the oil companies wanted to try out his machine....until now."It may seem an unlikely scenario that I'm the one delivering this technology at this moment in time, but from where I'm sitting, it is equally inconceivable that these machines are not already in place"
Btw, 15 other nations offer assistance to plug the oil well or help the clean-up efforts....yet our government declined. WTF??!! -
I can think of a few reasons.......
To protect Unions by not dropping the Jones act. That would allow foreign vessels into American waters to help. Bush did this during Katrina. Obama has yet to or maybe never will.
To prolong the disaster to push an agenda...as we see now, he is doing just that.
The man has been on the golf coarse twice as many times as he's been to the gulf....and went to 4 fundraisers too. Real concern...real leadership at it's best.HT SYSTEM-
lsi 9's -
Even the 'fluffers' at MSNBC were disappointed with last nights speech, and his lack of leadership:rolleyes:I refuse to argue with idiots, because people can't tell the DIFFERENCE!
So many people are whining about our president "not doing anything."
So, what more, exactly, would you have him do?"Wish I didn't know now what I didn't know then." Bob Seger -
I smell a thread closing...- Jeremy
Amps: Jolida FX-10, NAD 3045, NAD C320BEE, Sansui G-9700
Speakers: Polk Monitor 7A's, KEF Reference 104aB
Sources: ProJect Debut Carbon, Sonos streaming FLAC -
...I hate to say it. But a year away from American politics and Left vs. Right has been quite refreshing!
cnh
Man I hate to quote myself, but?Currently orbiting Bowie's Blackstar.!
BottomFeeder wrote: »So many people are whining about our president "not doing anything."
First,I would not have waited so long to get involved. Most importantly,I would have liked to see him accept help from everyone or anyone, that could supply materials,technology, to keep the oil from moving towards the shoreline. Also would like to see them accept help from anyone around the globe to STOP THE LEAK!! Instead,his intentions are towards dooming BP, reperations,criminal charges,and congressional hearings. You don't see them marching the guy from MMS who OK' ed the drilling being marched infront of congress. Since he claims he was in charge from day one, why did he not seek every bit of help he could ? Why is the Jones act still in place ? Why did he take so long to get involved ? Could you just for a second imagine if Bush was playing golf in the aftermath of Katrina ? Or attending fundraisers ? They would have torn him apart, even more so than they did. Obama is a master at redirected anger. Get everybody screaming for the heads of BP, but don't question the governments role in all this. He did this with healthcare,financial reform,bailouts, find a villian as long as it's not the government. Once he has directed that anger where he wants,it's easier to push legislation to expand the governments power. You don't have to be a Harvard grad to see that. Heck, most 5th graders could figure that out.HT SYSTEM-
lsi 9's -
First,I would not have waited so long to get involved. Most importantly,I would have liked to see him accept help from everyone or anyone, that could supply materials,technology, to keep the oil from moving towards the shoreline. Also would like to see them accept help from anyone around the globe to STOP THE LEAK!! Instead,his intentions are towards TAKING OVER BP, reperations,criminal charges,and congressional hearings. You don't see them marching the guy from MMS who OK' ed the drilling being marched infront of congress. Since he claims he was in charge from day one, why did he not seek every bit of help he could ? Why is the Jones act still in place ? Why did he take so long to get involved ? Could you just for a second imagine if Bush was playing golf in the aftermath of Katrina ? Or attending fundraisers ? They would have torn him apart, even more so than they did. Obama is a master at redirected anger. Get everybody screaming for the heads of BP, but don't question the governments role in all this. He did this with healthcare,financial reform,bailouts, find a villian as long as it's not the government. Once he has directed that anger where he wants,it's easier to push legislation to expand the governments power. You don't have to be a Harvard grad to see that. Heck, most 5th graders could figure that out.
I agree with everything you said here except the highlighted part... So I fixed it to reflect what is really happening.Considering the ongoing environmental crisis in the Gulf of Mexico, former Labor Secretary Robert Reich thinks the US government should takeover BP.
This story was originally covered by PRI's "The Takeaway." For more, listen to the audio above.
The US government took over General Motors and AIG when the actions of those companies threatened the US economy. Now that BP's actions are threatening the Gulf of Mexico, Robert Reich, the Secretary of Labor under Bill Clinton, told PRI's "The Takeaway" that President Obama should take over BP, too.
"The problem here," according to Reich, "is that BP not only has a terrible track record in terms of cutting corners and creating not only environmental problems but unsafe working conditions." Reich also believes that the American people can't trust the information coming from BP.
"The Obama administration keeps saying BP is in charge because BP has the equipment and expertise necessary to do what’s necessary," Reich wrote on his blog. And while that's true, putting the company in to temporary receivership could harness that expertise. It could also make sure that the expertise is used for the public interest, rather than the interests of shareholders.
The takeover would be temporary, under Reich's plan. Most importantly, though, it would put the President -- who is responsible to the American people instead of corporate shareholders -- in charge of the cleanup. Reich believes that temporary receivership would ensure that adequate resources would be devoted to the problem and that more truthful information would be shared. He told "The Takeaway:"
We have a national emergency in the Gulf -- obviously the most devastating environmental crisis we have had ever in our history. And to leave the major portion of the responsibility for cleaning up the gulf and for stopping that gusher to the company that created it in the first place, just seems unwise.
This is the way of the future... push a company to the brink and then assume control under the guise of "too big/vital to fail". Make no mistake, this administration is at war. Terrorists are no longer the enemy, the American way of life for since our founding is.The Gear... Carver "Statement" Mono-blocks, Mcintosh C2300 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon 680d DSD
Yup... I just checked outside. The sky is falling. Again. And that mean old black president is to blame.
Idiots.I never had it like this where I grew up. But I send my kids here because the fact is you go to one of the best schools in the country: Rushmore. Now, for some of you it doesn't matter. You were born rich and you're going to stay rich. But here's my advice to the rest of you: Take dead aim on the rich boys. Get them in the crosshairs and take them down. Just remember, they can buy anything but they can't buy backbone. Don't let them forget it. Thank you.Herman Blume - Rushmore -
Forum members,
While this is a subject that is important to everyone, we do need to keep it free from becoming a political discussion. Do we believe this can be prevented? Or, should we close it down?
Thanks for keeping the discussion relatively civil, so far.
Regards, Ken -
zombie boy 2000 wrote: »Yup... I just checked outside. The sky is falling. Again. And that mean old black president is to blame.
Idiots.
He's not mean, just the biggest empty suited idiot this country ever elected.
Carter part II.
You're going to LOVE the next 30 years. -
Five minutes ago, I picked up tickets for Arcade Fire and Spoon. General admission. Nothing is really going to get to me at this point.
Carry on.I never had it like this where I grew up. But I send my kids here because the fact is you go to one of the best schools in the country: Rushmore. Now, for some of you it doesn't matter. You were born rich and you're going to stay rich. But here's my advice to the rest of you: Take dead aim on the rich boys. Get them in the crosshairs and take them down. Just remember, they can buy anything but they can't buy backbone. Don't let them forget it. Thank you.Herman Blume - Rushmore
