Odds and ends
ChrisPCritter
I have a pair of Polk SDA I As and A pair of Bang & Olufsen beosound 8000 speakers and A Mirage center channel. Both the Polks and the Bang and Olufsens Sound phenomenal on their own but they sound really different from each other.
For Bass I have a Velodyne SPL 10 inch sub
I have a Dennon Avr receiver with a blown amp but the outputs work. I want to use the Polks up front using a
McIntosh 2125 to power them it is 120 watts per channel. And a Marantz 2025 to power the center it only has 25 watts per channel. The Bang & Olufsens each have two of their own built in amps so all they need is signal.
Does anyone have an opinion as to weather all these odds and ends will work together, and sound good?
I need to buy some wires to make it work so I thought I would ask first before I try this.
