adding ext. amp to receiver w/o preamp outs
maandjojo
Looking to add external amp to receiver that has no preamp outs. Does anyone have any suggestions. The speakers will be used for fronts in a 5.0 set up.
This is not my set up by the way.
Joe
Joe
Joe
Post edited by maandjojo on
Get a receiver with preouts.
There isn't really any way around it unfortunately.
You can get a converter that will turn speaker level outputs into line level outputs, but it drastically changes the output impedance and voltage...and won't really result in good SQ. It shouldn't even really be considered as a solution IMO.The nirvana inducer-
APC H10 Power Conditioner
Parasound Halo P5 preamp
Find either a receiver with pre-outs, or buy a preamp, a preamp & a tuner, or a preamp/tuner combo.polkaudio Monitor 5 Series II
polkaudio SDA-1 (with the SL1000)
TEAC AG-H300 MK III stereo receiver
beyerdynamic DT-880 Premium (600 Ω) headphones
SENNHEISER HD-555 headphones
Little Dot MK IV tube headphone amp
Little Dot DAC_I balanced D/A converter -
Thousands and thousands of years ago, both Carver and Soundcraftsmen sold a coupler box to do exactly what you want--connect a powerful amplifier to a receiver that doesn't have preamp-out jacks.
The Carver version might have been "Z-1"; and I'm sure the Soundcraftsmen product was "PC-1".
http://www.soundcraftsmen.com/other.htm
Basically, an impedance-matching transformer that didn't screw up the sound quality too much. Or, at least they HOPED it didn't screw up the sound quality too much. There are probably plans on the internet to build/source such a device; right next to the plans on the internet to build an atomic bomb. -
1)-Get a receiver with pre-outs.
2)-Use the above gizmo and HOPE it sounds OK.
3)-Tie into the first driver stage for your final amp(this SHOULD have enough voltage drive to do the trick, then impedance match-this takes a little know how and some skillz).
Of these three I HIGHLY recommend dropping the coin and going with option 1.Onkyo TX-SR705 AVR
Onkyo M-501-Given to my father.
Onkyo DX-C730 CD Changer
Onkyo DV-BD507 Blu Ray player
Onkyo CP-1036A turntable with Grado, Audio Technique, and Azden cartridges(GOT CARTRIDGE??)
Polk Monitor 12's with RDO's and XO's
Polk CS300 Center
Polk Monitor Series 4 rears
EBAY is like cocaine. At first you only look, next thing you know, your house is full of crap you have no idea why you own.:eek: -
Picking up a yamaha 665 w/pre outs.
Thanks for the help.
JoeJoe
