adding ext. amp to receiver w/o preamp outs
maandjojo
maandjojo Posts: 293
Want to use an external amp for more power, but the receiver does not have any preamp out connections. will want to use the speakers in concert with 5.1 set up. Any suggestions.
Joe
Joe
  • disneyjoe7
    disneyjoe7 Posts: 11,435
    edited May 2010
    In the end what are you're trying do?
    Is it 2 channel music? Or large front speakers for HT? If 2 channel you may like to get a pre amp first. There's no great way to add an amp now to to an AVR if there's no pre amp outputs, but in the end you want 2 channel music then another road is best.
    Speakers
    Carver Amazing Fronts
    CS400i Center
    RT800i's Rears
    Sub Paradigm Servo 15
    Electronics
    Conrad Johnson PV-5 pre-amp
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
    Sony CX400 CD changer
    Panasonic 42-PX60U Plasma
    WMC Win7 32bit HD DVR
  • comfortablycurt
    comfortablycurt Posts: 6,745
    edited May 2010
    I just posted this in your other thread...
    There really isn't any way around it. They make a converter that will turn speaker level outputs into line level outputs...but at a GREAT expense of SQ. It shouldn't even really be considered as a viable option IMO. It significantly changes the impedance and output voltage...and really isn't a good solution.
    Looks like it's time to upgrade the AVR.
    The nirvana inducer-
    APC H10 Power Conditioner
    Parasound Halo P5 preamp
