speaker terminal size?
![drballard33](https://w5.vanillicon.com/590fc0799f97ff2ffd0caa934c67ec65_100.png)
drballard33
I am very new to mobile audio and I was installing some db651's and noticed one terminal is smaller then the other, does anyoen know the size of this terminal or the right size cable connector I need to buy for it? the wiring on my boat for both + and - are the same size so I want to replace the terminals with new ones.
Sony STR-DG920 7.1 receiver
Sony 52" 120hz Bravia LCD
Sony SD350 Blu Ray
Polk surrounds and sub
Sony Blu Ray
DirecTV
Sony SD350 Blu Ray
Sony Blu Ray
DirecTV
Post edited by drballard33 on
The difference in terminal size is only to distinguish between positive and negative. The larger terminal is the (+) positive, and the smaller is the negative (-).
18 gauge cable would be suitable for your application.
The cable connector itself is imply a female spade.
If you have a radio shack around...
-- 1 package of these will give you all the little ends:
http://www.radioshack.com/product/index.jsp?productId=2103313
-- 1 package of these will give you all of the larger ends:
http://www.radioshack.com/product/index.jsp?productId=2104091
... about 5 bucks total for both.The Artist formerly known as PoweredByDodge -
Thanks that is exactly what I was looking for. I knew the difference in size meant but wasn't sure of the exact size I would need.
ThanksSony STR-DG920 7.1 receiver
Sony SD350 Blu Ray
Sony Blu Ray
DirecTV -
The small terminal is .110 and you can use a .250 for the large. A .187 might work for the large but the .250 will be just fine..
