CPU fan question
audiobliss
I have an Arctic Cool Freezer 7 Pro cooling my CPU, and it's always done a good job. At idle and small demand, it'll spin about 400-500rpm. When I check the speed after gaming, it's usually no more than around 700rpm. Well, I noticed some case temps going up slightly and the CPU fan speed was getting up to 800rpm after gaming, so I thought I'd clean it out. I got a can of compressed air and cleaned out all the fans, vents, fins, etc as best as I could and started her up again. Now, at idle, the CPU fan is spinning at 1044rpm. I'm not sure I've ever seen it spin that fast.
What's going on?? Why did it go up after I cleaned it out? And why is it that fast just browsing the internet? I'm just kind of confused here on this one...
In UseGeorge Grand wrote: »
Epson 8700UB
In Storage
[Home Audio]
Klipsch RF-35, RB-51ii
[Car Audio]
Post edited by audiobliss on
I thinking a heat sensor which is controlling the CPU fan speed is still a bit cold as the air is most likely a refrigerate. I don't think you have anything to worry about, at least right now.
Speakers
Carver Amazing Fronts
CS400i Center
RT800i's Rears
Sub Paradigm Servo 15
Electronics
Conrad Johnson PV-5 pre-amp
Parasound Halo A23
Pioneer 84TXSi AVR
Pioneer 79Avi DVD
Sony CX400 CD changer
Panasonic 42-PX60U Plasma
WMC Win7 32bit HD DVR -
I agree with Joe, I don't think anything is too wrong. Check out the Cooler Master Hyper 212+. You can get them on Newegg for $30 which is a steal cause they're pretty much the best CPU cooler on the market without getting into water cooling.
I know you weren't asking for a replacement, but guys like us are always looking for an excuse to upgrade.polkaudio sound quality competitor since 2005
I think everything is fine. According to my BIOS, the CPU fans vary a lot and it depends on a variety of factors.
You should be okay.polkaudio RT35 Bookshelves
polkaudio 255c-RT Inwalls
polkaudio DSWPro550WI
polkaudio XRT12 XM Tuner
polkaudio RM6750 5.1
well if it was a result of the air cooling(as a refrigerant would do) the fans would spin slower as their is less heat to get rid of.
I'd say it has more to do with ambient temps. It's getting warmer out. All winter my cpu, while browsing the internet, would sit at 28 degrees C. Now that we have had temps constantly over 50 out side my cpu at idle is at 34 degrees C.
Just keep an eye on it. If you can keep an eye on your temps and if you see 60 C. I'd start to worry.
Best of luck,
Ted -
Actually I had this happen on one of my older rigs and believe it or not dust can cause this easily. Most CPU fans will spin around 1000 or more rpm's. At 700 or so, I'm surprised the bios didn't shutdown the PC. In some cases it will, easiest way to tell if your CPU fan is doing it's job is go in the bios and go into PC health status. I have dual fans on my CPU both running at 1500 rpm. Also in the bios of newer mobo's you can control fan speed, etc good for overclockers.Shoot the jumper.....................BALLIN.............!!!!!
Thanks for the input, folks. I guess I'm not really worried about it, just moreso really curious as to why it jumped up like that.
At any rate, I'm really excited about my computer, as I'm upgrading it this summer. I've already upped the RAM (going to up it some more, I think), am currently RMA'ing a DOA 1TB HD ( but ), and JUST placed an order for a GTX260 (moving up from a 7900GS!)!!! New case for better airflow will be next on the agenda, then I can delve into OC'ing this Q6600 finally!George Grand wrote: »
Epson 8700UB
In Storage
[Home Audio]
[Car Audio]
Pioneer Premier DEH-P860MP, Memphis 16-MCA3004, Boston Acoustic RC520 -
And, thanks, Mac. That's the last thing I need! I had to work REALLY hard (friends did, too) to talk myself out of splurging on a 5850!George Grand wrote: »
Epson 8700UB
In Storage
[Home Audio]
[Car Audio]
audiobliss wrote: »And, thanks, Mac. That's the last thing I need! I had to work REALLY hard (friends did, too) to talk myself out of splurging on a 5850!
I see a Zalman cooler in your future =P.Panasonic PT-AE4000U projector for movies
Denon AVR-X3600H pre/pro
B&W CDM1-SE fronts
B&W CDM-CNT center
B&W CDM1 rears on MoPADs
DUAL NHT SubTwo subwoofers
Oppo BDP-93 Blu-Ray player
Belkin PF60 Power Center
Sony XBR-X950G 55" 4K HDR Smart TV + PS3 in the living room -
Just got the GTX260 delivered and installed today! Had to remove a few things and rearrange the HD's to make room for it in my current case. Now I just can't wait to bring the upgrades all together with a new case!
And man, this GPU is rocking! Certainly a huge upgrade from my 7900GS. I'm loving it!George Grand wrote: »
Epson 8700UB
In Storage
[Home Audio]
[Car Audio]
Yeah, that GTX260 is a very solid card. Should handle pretty much anything at max graphics with only a few exceptions.polkaudio sound quality competitor since 2005
Nice card bro. I'm running a GTX 275 now and loving it. After reading this thread, I took down my PC, fired up the air compressor got the case all blown out. Fans, my Dark Knight heatsink, all nice and looking new again.Shoot the jumper.....................BALLIN.............!!!!!
Yeah, that GTX260 is a very solid card. Should handle pretty much anything at max graphics with only a few exceptions.Nice card bro. I'm running a GTX 275 now and loving it. After reading this thread, I took down my PC, fired up the air compressor got the case all blown out. Fans, my Dark Knight heatsink, all nice and looking new again.George Grand wrote: »
Epson 8700UB
In Storage
[Home Audio]
[Car Audio]
Agreed, feels and looks fresh. I've had the 275 for awhile now. It's a bit overkill for what I do with this rig but it's nice to have. I'm thinking of upgrading my current SSD to a Intel160 gb. I have an Intel 80gb in there now and its awesome.Shoot the jumper.....................BALLIN.............!!!!!
I'd love to be able to go with SSD's, but it will be quite a while before they come down in price enough for that to be possible!
Unless, of course...I were to come across a used SSD in good shape...:DGeorge Grand wrote: »
Epson 8700UB
In Storage
[Home Audio]
[Car Audio]
my coolermaster hyper 7 r getting very noisy after 3 yrs of use. swtiching to zipang (super quite, and decent cooling) soonFront: Martinlogan ESL
Center: Martinlogan Stage
Rear: Martinlogan Motion 4
Sub: Martinlogan Grotto-I
Receiver: Pioneer Elite SC 1523K
PC 2 Channel: Polk LSI7
Headset: Grado RS2 + Grado RA1 amp
Mic: Neumann KMS605
Car Audio
2002 MB C240 Sedan
MM6501 components
MM840 sub
MB Quart Onyx 4.60 (1/2 to components, 3/4 bridged to sub)
Pioneer 8200BT HU -
audiobliss wrote: »However, if they still had GTX275's still available, I definitely would have gone for that.
You pass on a 5850 but would go for a GTX275??? You goober! A 275 aint really that much faster than a 260 where the 5850 just stomps on both of those cards for the same price as the 275!
Trust me, I know these things. I dont have a life so I sit around and read benchmark reviews all day.polkaudio sound quality competitor since 2005
However, I didn't delve into prices that much. If the 5850 and GTX275 are the same price, then...well phoo. Doesn't matter anyways. Can't afford more than the 260. And it's being great to me so far!George Grand wrote: »
Epson 8700UB
In Storage
[Home Audio]
[Car Audio]
