How to setup my avr as pre
EDUBAG
Hello everybody,
i currently own a pioneer elite vsx23txh and was using it to drive my rtia7 speakers.
Since everybody here knows that the rtia7 tend to be a little bright i went ahead and purchased a rotel rb990bx amp, because according to a lot of people here it provided a warm sound.
I went ahead and hooked to the pre outs on the avr and ran the mcacc automatic calibration software of the pioneer.
I did not like the sound at all it killed, i mean literally killed the brightness of the music.
Played some cd and it sounded muffled and not louder or fuller.
I am wondering if there is a way to know if i am using the avr correctly as a pre. I have to push the volume all the way to -10db to feel the speakers come alive.
I would like to know if there is a loud function on this avr or a proper way to set up so the speakers can sing and i can enjoy their full potential
any advice will be greatly appreciated
regards,
ed
regards,
ed
HT:
POLK AUDIO RTI4 FRONTS
CSI3 CENTER
DEF TECH PROMONITOR800 SURROUNDS
PSW 125 SUB
PIONEER ELITE AVR23TXH AVR
APPLE TV 160GB
PANASONIC BLURAY PLAYER
50" PANASONIC PLASMA TCP50C2
2 CHANNEL:
KEF R300 THREE WAY BOOKSHELF GLOSS PIANO BLACK
ROTEL RC 990BX PRE
ROTEL RB 990BX AMP
OPPO DV980 (AS CD PLAYER)
PIONEER PL100 TURNTABLE WITH SHURE MX97E CART
MIT EXP2 SPEAKER CABLES
CSI3 CENTER
PSW 125 SUB
APPLE TV 160GB
2 CHANNEL:
ROTEL RC 990BX PRE
ROTEL RB 990BX AMP
Post edited by EDUBAG on
you should be able to adjust the gain of your amplifier. try that.
it cannot be adjusted, most home amps do not have a gain control, most of them go by what the pre feeds them.HT:
CSI3 CENTER
PSW 125 SUB
APPLE TV 160GB
2 CHANNEL:
ROTEL RC 990BX PRE
ROTEL RB 990BX AMP
MIT EXP2 SPEAKER CABLES -
If I had that issue with that AVR, I would do a factory reset, and then see how it sounds WITHOUT running the automatic setup software. Worth a shot. I have had a Rotel amp, and I would definately NOT say it was 'muffled', warm, yes.
I would NEVER use the "Loundness" button...good way to trash some speaks. -
I would run your MCACC setup again to see what you think after that.
Speakers
Carver Amazing Fronts
CS400i Center
RT800i's Rears
Sub Paradigm Servo 15
Electronics
Conrad Johnson PV-5 pre-amp
Parasound Halo A23
Pioneer 84TXSi AVR
Pioneer 79Avi DVD
Sony CX400 CD changer
Panasonic 42-PX60U Plasma
WMC Win7 32bit HD DVR -
disneyjoe7 wrote: »I would run your MCACC setup again to see what you think after that.
You have to run MCACC with the amp installed and mentioned by DisneyJoe. Also suggest you break out the SPL meter and tweak a little. That Rotel should be making you feel even better about your setup.Shoot the jumper.....................BALLIN.............!!!!!
I ran that same receiver with three different out board amps with very good results. As Kcoc has suggested already do a reset and start from scratch. I would also recommend that you start out in pure direct mode and give a listen for sound quality. Another item is; Are you linking these together with a decent IC?Parasound C1, T3, HCA-3500, HCA-2205A, P/DD1550, Pioneer DV-79avi, Oppo BDP-83, WD Media Server W/HDD,
Dynaudio Contour 3.3, Dynaudio Contour T2.1, Polk OWM3, Polk DSW micropro 1000 (x2),
Pioneer Kuro 50" Plasma, Phillips Pronto Control w/Niles HT-MSU. -
After I installed my Rotel, I ran the MCACC again....I can't say enough good things about that AMP.Polk Audio Surround Bar 360
Mirage PS-12
LG BDP-550
Motorola HD FIOS DVR
Panasonic 42" Plasma
XBOX 360[/SIZE]
Office stuff
Allied 395 receiver
Pioneer CDP PD-M430
RT8t's & Wharfedale Diamond II's[/SIZE]
Life is one grand, sweet song, so start the music. ~Ronald Reagan -
like i said,
i am sure that the amp is capable of bringing good sound, i just do not know if i am using the avr as a pre in a correct manner.
anybody familiar with the vsx23txh can help by stating how they are using theirs, is there a loud mode in this avr? etc.
regards,
edHT:
CSI3 CENTER
PSW 125 SUB
APPLE TV 160GB
2 CHANNEL:
ROTEL RC 990BX PRE
ROTEL RB 990BX AMP
Pure Direct, no mcacc.Parasound C1, T3, HCA-3500, HCA-2205A, P/DD1550, Pioneer DV-79avi, Oppo BDP-83, WD Media Server W/HDD,
