Satellite for Rears and a Sub
bp_
bp_ Posts: 6
edited May 2010 in Speakers
A couple questions. My current setup is in my sig.
1) I am currently using some crappy old satellite speakers for my rears. Are there any Polk Satellite's that would be recommended to be used with the monitor series? I want satellites for my rears because they are small.
2) I am using an old sub that I would like to replace. The PSW110 seems like it would be appropriate for my setup but it is so big. Is there a sub that is smaller that anyone would recommend for my system?
The suggestions can be polk or not but I would like to get the same black woodgrained finish that my monitor speakers have. I'm also building a budget system as you can tell from my center and front selections so keeping cost in mind would also help.
Thanks!!
Denon AVR-790
Samsung 40" LCD HDTV
Samsung DVD
Fronts: Monitor 50s
Center: CS1
