Receiver for VM's and JBL N series speakers
blockatvalpo
blockatvalpo Posts: 87
edited May 2010 in Speakers
I currently have two receivers in my house and I’m trying to figure out which receiver is best for each set of speakers.
Set-up 1 (primarily used for movies and xbox):
VM30-front
VM20-center
RM6751-surround
SVS cylinder sub
Set-up 2 (used for tv, movies, music, and the ps3):
JBL N38II-front
JBL N Center
JBL N24-surround
Kenwood SW-1050-subwoofer
Receivers:
Marantz SR6001
Kenwood VR-6060
I’m thinking about using the Kenwood for the VM’s and the Marantz for the JBL’s. I currently have them set-up the other way around and the more I think about it, I think I might get better sound if I swap them. Thoughts?
Post edited by blockatvalpo on
  • blockatvalpo
    edited May 2010
    Well I switched the receivers around last night and I can tell a difference in my N series speakers. Now that the VR-6060 is hooked up to my Polk VM30's, I will probably look for a receiver to replace it. The shelf on my tv stand for the receiver is only 9 inches tall, so it might be hard finding a receiver for that space. I already plan on putting a fan next to it to blow the hot air away, bc the shelf won't give me the proper ventilation.
