Tweaking my RT55's and CS400
Ron-P
These are my front 3 main speakers in my HT room. I've had them a very long time. I think I am ready to upgrade there components, thing is, I have no idea what to do or how to do it. Maybe crossover tweaks, new drivers / tweeters. I don't know but I wouldn't mind doing something.
Any ideas, tips or suggestions?
If...
Ron loves a film = don't even rent.
Post edited by Ron-P on
Patrick listed some mods for these a while back and said they were a very good improvement...Pio Elete Pro 520
Panamax 5400-EX
Sunfire TGP 5
PS Audio GCPH phono pre
Sunfire CG 200 X 5
Sunfire CG Sig 405 X 5
OPPO BDP-83 SE
Ctr CS1000p
Sur - FX1000 x 4
SUB - SVS PB2-Plus
Workkout room:
Onkyo TX-DS898
GFA 555
Yamaha DVD-S1800BL/SACD
Ft - SDA 1C
Not being used:
RTi 38's -4
RT55i's - 2
LSI 15's
CSi40
PSW 404 -
Any idea where I could find that info?If...
Ron loves a film = don't even rent. -
Have you thought about trying some different speakers?
My bad, it wasn't Patrick...sorry, see this thread, post 60 is what I was "trying" to remember:o
http://www.polkaudio.com/forums/showthread.php?t=79767Pio Elete Pro 520
Panamax 5400-EX
Sunfire TGP 5
Sunfire CG 200 X 5
OPPO BDP-83 SE
Ctr CS1000p
Sur - FX1000 x 4
SUB - SVS PB2-Plus
Workkout room:
Onkyo TX-DS898
GFA 555
Ft - SDA 1C
Not being used:
RTi 38's -4
RT55i's - 2
LSI 15's
CSi40
PSW 404 -
That would be me
The simplest and most effective route is replacing the capacitors on the RT55 and CS400 crossovers. Very simple to do with basic soldering skills.
Simply replace the Electrolytic capacitors with Polypropelene capacitors, equal values, however i recommend uping from the "stock" 50volt caps to 250 volt caps. -
If space allows, replace midrange and woofer caps with Dayton or Claritycap. As for the tweeter circuit, it may have a film and electrolytic cap in parallel, combine both values and replace with a single, high quality film cap such as a Sonic Cap or Claritycap PX/SA."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
^ Great input.
OP dont stress over spending alot of money on caps though, I tested Solen, Dayton, Claritycap. Between the 3 there was negligable differances on the RT55 and no discerable differance on the CS400. -
So by doing this what exactly will it do, or change, with my speakers?If...
Increase transparency, coherency, dynamics, etc..."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
^ this. By replacing the electrolytic caps with Polypropelene caps you reduce the amount of signal loss across the electrical network, which in turn increases transparency, dynamics, coherency, etc...
