A few questions from a Noob
jjhumperdink
jjhumperdink Posts: 4
edited May 2010 in Speakers
Hey guys, I'm building my first decent home theater and have a few questions. I just bought a pair of tsi300's and am looking for a center and sub to match. Been looking at the cs20, but am not too sure on the sub. My living room is rather large, so I want to make sure whatever I get will fill the room. Any suggestions on subs? How about the cs20? I'm running everything with a Onkyo sr605 that I've had for about 2 years. Any help would be greatly appreciated. THANKS!
Post edited by jjhumperdink on
  • Slinger182
    Slinger182 Posts: 512
    edited May 2010
    CS20 will suite you well. What's your budget for the sub?
    Panny 55-st30 plasma
    Pioneer vsx-1121
    Parasound 2100 pre
    b&k tx4430 amp
    Oppo bdp-83
    Monster HTS 3500
    polk TSi500s Vr3 Fortress modded
    polk CS20 center channel Vr3 Castle modded
    polk Owm 3 surrounds
    polk PSW505
  • jjhumperdink
    edited May 2010
    Don't really want to spend more than $250-$300, but I'm willing to if need be. Thanks for the info on the cs20's Slinger.
  • Slinger182
    edited May 2010
    I have this sub and love it. http://www.newegg.com/Product/Product.aspx?Item=N82E16882290130
    It's seems to be a good deal that everybody recommends, sometimes it will go down to $225 with free shipping if you want to try and wait. HSU makes another one in that price range that gets recommeded a lot but I don't have any experience with that.
    Unless you want to go used. I don't know much about much about that either but I'm sure if you want to do the work looking for one you could find one.
    Pioneer vsx-1121
    Parasound 2100 pre
    b&k tx4430 amp
    Oppo bdp-83
    Monster HTS 3500
    polk PSW505
  • jjhumperdink
    edited May 2010
    Thanks! I'm gonna look into the sub.
  • Slinger182
    edited May 2010
    Oh and welcome to the club stick around and you'll learn a ton and the people are cool and are awesome and spending your money for you:D
    Pioneer vsx-1121
    Parasound 2100 pre
    b&k tx4430 amp
    Oppo bdp-83
    Monster HTS 3500
    polk PSW505
  • packetjones
    packetjones Posts: 1,059
    edited May 2010
    I would recommend the CS20 as well. It is the larger of the 2 centers in the TSI line and will fit nicely. Especially if this is for a HT setup.
    In regards to the sub, the 505 recommended before is nice. Also look into the STF/VTF series' from HSU. There is also the PB10-NSD available from SVS. It is the lowest priced SVS sub and is a little more that you are listing as a budget though.
    Front - RTiA5's
    Rear - RTiA3's
    Center - CSiA4
    Sub - PSW110
  • On3s&Z3r0s
    On3s&Z3r0s Posts: 1,013
    edited May 2010
    I have the PSW505 too and can definitely recommend it for home theater. It's not a very musical sub, so if you were planning on listening to much 2 channel music on your home theater and using the sub to compliment the fronts, I'd maybe give the others mentioned a try. One thing that helped a little... the PSW505 comes with just some hard plastic feet that are nailed into the bottom of the enclosure. I took those out and installed some aftermarket carpet spikes. I'd recommend that to tighten up the bass if you're going to have it on carpet.
  • jjhumperdink
    edited May 2010
    Thanks for all the suggestions. Gonna look into everything today.
    edited May 2010
    WELCOME TO CLUB POLK!
    +1, on all the suggestions above....
    cnh
