Monitor 30 with RM85
edited May 2010 in Speakers
Hi everyone!, I'm new here. I want some advise about setting a 7.1 HT. The base will be a 5.0 RM85 package, I own a PSW110 as my LFE. So I need to complete the 7.1 set. My first options are:
  • RM8's as fronts, RM7s as Surrounds and a new pair of RM7 for back surrounds
  • RM8's as surrounds, RM7s as back Surrounds and a new pair of Monitor 30 for the front
  • RM8's as surrounds, RM7s as back Surrounds and a new pair of Tsi100 for the front
Wich one of the last two will sound better with the RM8 center?
Post edited by Jdelgado on
    edited May 2010
    Just my .02 (however doesn't mean I'm right);
    Monitor 30 or TSi 100 do not seem appropriate unless you consider a new center that would match such speakers otherwise I think you should stick with the RM series for now until you can upgrade accordingly. Maybe just buy another RM center for now which will provide you for a 6.1 set-up and once your budget can provide, you can then cover front with Monitor 30 or Tsi 100 + appropriate center and move the RM centers as surrounds (you would simply need to change your grills)?
    Cheers!
    TK
    DARE TO SOAR:
    “Your attitude, almost always determine your altitude in life” ;)
    edited May 2010
    Thanks for the advise!
Welcome!
Welcome!
