Sound question.
souljurn
I have two GNX12 4 ohm subs in a Q-Logic sealed/ported box (QLH-1.2512dx) (1.25 cubic feet internal volume per sub). Running them i changed my amp from a Profile to a Rockford Fosgate Power 351M
175 watts RMS x 1 at 4 ohms
350 watts RMS x 1 at 2 ohms.
I want to know, since im still in my breaking in period, if these subs will pound and hit or will they just deliver tight well pronounced bass in the box mentioned?
I also have a Blaupunkt Casablanca CD51 CD Receiver
25 watts RMS/50 peak x 4 channels
4v front/rear/mono subwoofer outputs
going into the amp.
going into the amp.
Post edited by souljurn on
since it sounds like a bandpass box, it will probably be ok for rap/hip hop, not so much a tighter sound found in metal. probably not tight, just boomy.At Home:
Panasonic 42'' TC-L42U12 LCD
Pioneer VSX-80TXV
Toshiba HD-XA2
Sony PS3 - psn "metalguitars"
Xbox 360 - gamertag "giggidygiggidy"
Panamax 4300EX
Polk RTi8's
Polk CSi3's
Polk FXi3's. (x2)
Martin Logan Dynamo (x2)
Audioquest interconnects and wires.
Away From Home:
JVC HDR-50
stock system in new car for now:(
