Changing out the speaker terminals on my Carver amp
kalebfulk
Hi, i'm new to the forum, this is my first post. I have a Carver m1.0T amp, and i want to change the speaker terminals out on it. mainly, the original ones don't have the banana plug socket, and the plastic is starting to crack. i have found a couple terminals for sale on ebay, though i'm not sure if they will fit in the original holes on the amp, or if the space will be the same so i can use banana plugs. any help would be very much appreciated, i.e., walkthroughs, and products to buy.
thanks very much!
-kaleb
thanks very much!
-kaleb
Post edited by kalebfulk on
Kalebfulk,
you may want to try asking at www.thecarversite.com You will have to register, but you are more likely to find someone who has performed the modification you are asking about.
good luck! -
thanks Cincycat13!
http://www.thecarversite.com/yetanotherforum/default.aspx?g=posts&t=2384
You are welcome. If you got registerd, here is a link to discussion for binding posts for the m1.0t
