A tad aggressive with the volume knob...
Ron Temple
...on my 1Cs last night. Had the pre close to noon and heard one of my 6511s making a farting noise (the lower driver handling more bass). Examined it and it seemed to be pushing more air than the other speakers. I recently Mortited these speakers so I know the seal is good. Backed off the volume and everything came correct, but I'm wondering if this MW is starting to go. Doesn't look to have a tear in the surround. Any thoughts?
Combo rig:
SDA 1C, CS400i, SDA 2B
PB13Ultra RO
BW Silvers
Oppo BDP-83SE
Post edited by Ron Temple on
Maybe it's time to recap your amps?"He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
That's on the to do list, but why just one of the drivers?
Combo rig:
PB13Ultra RO
BW Silvers
Oppo BDP-83SE -
Farting noise and reduced bass from one driver sure would make me suspect an air leak (or perhaps some other mechanical problem) at that driver.
The 6511s are wired in series, an electrical fault with one should affect the other the same way. -
Ron, is it an original or newer 6511?
Greg
"Have A Little Faith! And Everything You'll Face, Will Jump From Out Right On Into Place! Yeah! Take A Little Time! And Everything You'll Find, Will Move From Gloom Right On Into Shine!"- Arthur Lee -
I guess I'll pop the driver and check the seal and connection. There was definitely more air being pushed and that could be a leak.Farting noise and reduced bass from one driver sure would make me suspect an air leak (or perhaps some other mechanical problem) at that driver.
Combo rig:
PB13Ultra RO
BW Silvers
Oppo BDP-83SE -
It's an original...might be a replacement I picked up from Polk65. I did have one go bad a few years ago.Ron, is it an original or newer 6511?
Greg
Combo rig:
PB13Ultra RO
BW Silvers
Oppo BDP-83SE -
Ron Temple wrote: »It's an original...might be a replacement I picked up from Polk65. I did have one go bad a few years ago.
Hmm, not sure then. I had a newer 6511 I got from Polk that would get overloaded easily when you pushed it with somewhat high dB levels. If it's an original it may be time to replace it. Does it still move freely without any rubbing at all?
Greg
I just popped it and can see nothing wrong. I must have been pushing it pretty hard last night. I'm at 9AM on the dial right now and am measuring 90dbs at 3M...no issue and it sounds pretty loud to me (now). I was probably in the 105db plus range...sounded goodHmm, not sure then. I had a newer 6511 I got from Polk that would get overloaded easily when you pushed it with somewhat high dB levels. If it's an original it may be time to replace it. Does it still move freely without any rubbing at all?
Greg
, until the farting. I think I had the single malt itch going a bit too much. Wife's out of town visiting some of our kids in San Diego.
Combo rig:
PB13Ultra RO
BW Silvers
Oppo BDP-83SE -
Go Ron ! Just be careful;)Speakers: SDA-1C (most all the goodies)
No DUI possible here...having a home office makes my commute negligibleGo Ron ! Just be careful;)
. Oh, you mean back off the MV :eek:.
Before I broke out the Luxman 2 channel pre, I was listening to Porcupine Trees new DVD in MCH at reference level, so naturally I was used to LOUD when I changed over.
Combo rig:
PB13Ultra RO
BW Silvers
Oppo BDP-83SE -
I love my wife but when she takes a trip to visit her family and I have the house to myself I have no problems having a good time.
A few drinks and find myself pushing a little hard too.
Hvae a good time and enjoy.
Good to see you posting.Speakers: SDA-1C (most all the goodies)
I've been around, just not posting much. I've been very busy and it's been important stuff, so I don't chime in unless my interest is really peaked...or I have a problemI love my wife but when she takes a trip to visit her family and I have the house to myself I have no problems having a good time.
Combo rig:
PB13Ultra RO
BW Silvers
Oppo BDP-83SE -
I pushed mine too almost noon today, and it was freaking loud,and I very seldom do that anymore but once in awhile its fun..
Glad to hear everythings OK.. -
It will eventually fail. I've seen this many times.CTC BBQ Amplifier, Sonic Frontiers Line3 Pre-Amplifier and Wadia 581 SACD player. Speakers? Always changing but for now, Mission Argonauts I picked up for $50 bucks, mint.
Agreed. That driver is on its way out.Political Correctness'.........defined
President of Club Polk -
It will eventually fail. I've seen this many times.F1nut wrote:Agreed. That driver is on its way out.
That's what I was thinking. Thanks for the confirmation.
Combo rig:
PB13Ultra RO
BW Silvers
Oppo BDP-83SE -
If by pushing more air, you mean it's moving in & out more than the others at a given volume, then my guess is you've melted a portion of the voice coil. This makes the overall impedance of that speaker lower & requires more current from your amp. I would check the impedance of that individual driver against the others for any variation.TNRabbit
NO Polk Audio Equipment :eek:
Sunfire TG-IV
Ashly 1001 Active Crossover
Rane PEQ-15 Parametric Equalizers x 2
Sunfire Cinema Grand Signature Seven
Carver AL-III Speakers
Klipsch RT-12d Subwoofer
