Bad tweeter?
I bought a pair of RTi A1's off polk direct a couple months ago, and I finally got a receiver for them. I ran through the Audyssey setup on my Onkyo 608 today (twice to make sure it wasn't an error), and both times it set my right speaker 8-9db higher than my other speakers.
I went in to the setup menu to correct what I though was an error. When you select each speaker it plays static through them so you can compare each. When I select the right speaker, the static is noticably lower pitched and if I take away the db boost that audyssey set the speaker is also noticably quieter.
Does this mean my tweeter is bad? What else could I try to confirm this?
Post edited by DaveHCYJ on
It sounds like it's doing what it's supposed to be doing.
Audyssey sets the speakers up to work better in your room, and sometimes this requires the level of one(or more) speaker(s) to be significantly higher than the others.
Have you listened to the speakers yet? Put your ear up to the tweeter in question and see if you can hear anything. If you can't hear anything, or it sounds staticy, there could be a problem. From what you're describing though, it doesn't sound as if anything's wrong.Jhon Smitch wrote: »There may be a fuse, but getting to it may require taking the woofer out and looking inside the speaker. The crossover also may be removed from the rear where the speaker wire connects. You may have to remove the speaker wire connector plate. The crossover may be on the back of it. If you do find the fuse, you can then take the good fuse out of the other speaker to try it.
There has to be some way to access the crossover. It is also possible that the crossover is bad.
There aren't any fuses on the RTiA1's. To the OP, don't follow this douches advice.
Also, your post has been reported, spammer.The nirvana inducer-
APC H10 Power Conditioner
Parasound Halo P5 preamp
You may want to do the paper towel roll test....put the cone to the tweeter to isolate the sound on both speakers.Retired Onkyo 520 (returned broken HK 247)
Now a Pioneer 1018
CSi3
2- RTI10's
2- R50's
2- Fxi3's
Onkyo 250W Sub
Polk psw-10
"Inch by inch lifes a cinch, yard by yard life is hard" -
Call the Polk customer support line: 1-800-377-POLK
They'll help you figure out if you have a tweeter problem or not.
They're great to work with - helped me out before.HT
Onkyo TX-NR1008 | Magnepan 1.7 | Polk LSiC | Polk VM20 | Polk DSW microPro 2000 | Parasound HCA-2205A | Oppo BDP-93
2-Ch
Cary SLP 30 Tube Preamp | Polk LSi7 | Carver M1.5t | Audio-gd Digital Interface | W4S DAC-2 | MAC Mini | Denon DP300f & Pro-Ject Debut III TT's -
Turns out when I hooked up the speakers I unscrewed the top binding posts also (don't know why I did that...) and forgot to screw them back down after attaching the speaker wire to the bottom posts. Doh!
While tightening the top posts I could hear the tweeter come on.
I didn't have time yet, but I plan on clearing the Audyssey calibration and then doing the "paper towel" test to make sure things are in order and then I'll run Audyssey again.
Thanks for the suggestions!
Edit: I guess this should have gone in the troubleshooting forum. Sorry, still new here.
