Two amps to one set of RtiA5's
specd_out
specd_out Posts: 504
I know this sounds like a really stupid question, but let me explain my situation.
My setup
Yamaha VX463
Rtia5
Csi3
T-15
DSW Pro 600
I love my 463 It works great for my HT but I know I can do much better for 2ch music listening. The problem is that the 463 does not have preouts, and I dont think its wise for me to spend $400+ for a new AVR with preouts and then spend another 300+ for a 2ch amp.
Here is what I wanna do. My dad has a carver amp that he isnt currently using. i would like to run my cd player directly to the carver and then power my rtia's with the carver, But I still want my Rtia's to be used in my HT. So in simple terms my question is, Can I have both amps wired to my speakers and not have any issues. As long as they arent both on at the same time I cant seem to think of any downsides to doing this. I am still a novice in HQ audio so this is why I want to ask your guys opinions on this.
HT Rig Samsung 64F8500 |Pioneer Elite BDP-52FD|Pioneer Elite VSX-32| Two Carver TFM-15cb Bridged for mains|Polk Audio RTiA5 Cherry|Polk Audio CsiA6 Cherry|Polk Audio T-15 Heights|Polk Audio FXia6 Surround|DIY 8cuft Dayton Ultimax 15" powered with a Crown XLS1000
2Channel Rig Polk Audio LSi9 Cherry| Carver C-1BillD Mod|Carver M1.0t MkII Opt2|Pro-ject RM 1.3|SpeedBox S|AQ King Cobras|AQ Rocket88|
ISF Level 2 Certified Calibrator
    nooshinjohn Posts: 26,181
    edited May 2010
    I would not recommend this...
  • quadzilla
    quadzilla Posts: 1,543
    edited May 2010
    Yeah, neither would I. Maybe banana plugs then swap the cables depending on what you want to listen to.
    Turntable: Empire 208
    Arm: Rega 300
    Cart: Shelter 501 III
    Phono Pre: dsachs consulting
    Digital: Marantz SACD 30n
    Pre: Conrad Johnson ET3 SE
  • specd_out
    edited May 2010
    I have banana plugs already. Just out of curiosity why isnt this a good idea.
  • disneyjoe7
    disneyjoe7 Posts: 11,435
    edited May 2010
    Doing so feeds voltage / current back to amp which is off, and in the wrong direction since it designed to feed not to be feed.
    Speakers
    Carver Amazing Fronts
    CS400i Center
    RT800i's Rears
    Sub Paradigm Servo 15
    Electronics
    Conrad Johnson PV-5 pre-amp
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
    Sony CX400 CD changer
    Panasonic 42-PX60U Plasma
    WMC Win7 32bit HD DVR
  • specd_out
    edited May 2010
    disneyjoe7 wrote: »
    makes sense to me. Thanks
    pitdogg2 Posts: 27,917
    edited May 2010
    disneyjoe7 wrote: »
    Doing so feeds voltage / current back to amp which is off, and in the wrong direction since it designed to feed not to be fed.
    fixed it to be more clear:)
  • disneyjoe7
    edited May 2010
    Thanks I'm always clear.... Drugs? Lack of or too many before?
    Speakers
    CS400i Center
    RT800i's Rears
    Electronics
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
  • TECHNOKID
    TECHNOKID Posts: 4,298
    edited May 2010
    specd_out wrote: »
    My setup
    Yamaha VX463
    Rtia5
    Csi3
    T-15
    DSW Pro 600
    This AB selector switch (http://www.volutone.com/RUSS-AB22-TBL-TOP-SPEAKER-P692.aspx) would allow you to use your 463 and Dad's Carver amp safely on the same pair of speaker.
    Cheers!
    TK
    DARE TO SOAR:
    “Your attitude, almost always determine your altitude in life” ;)
  • specd_out
    edited May 2010
    ^ Thanks Thats definitely a option
