Any iPhone experts out there?
donahue
donahue Posts: 125
edited May 2010 in The Clubhouse
Ok, so my daughter wants an iPhone to replace her existing phone, which is broken. All she wants it for, is for making calls, texting and the iPod functionality. I want to get an iPhone off eBay, or similar site, but am a bit confused as to what exactly I should be looking for. Since we already have AT&T, I don't think I need to buy and unlocked phone. There are 2G, 3G and 3GS iPhones available, but I'm not sure if an existing AT&T sim card will fit in which model.
Any feedback would be greatly appreciated.
Thanks,
Ray
Post edited by donahue on
  • flason
    flason Posts: 278
    edited May 2010
    AT&T has refurbed 3G's for $50.
  • rooftop59
    rooftop59 Posts: 8,121
    edited May 2010
    flason wrote: »
    +1
    Perfect route to go, especially for your daughter. This way you don't have to worry about sketchy dealers or used phones. When you buy the phone from ATT (buy it online) it will come shipped with a sim card in it (they are not supposed to be removable). The 3G can do everything she wants and more. I have one and love it. However, if she wants to carry a lot of music on it, you might pony up for the 16 gb model which is 99 refurb.
    If she really only wants it for calling, texting, and music, you might want to look at other phones. You have to pay an extra 30 bucks a month for the data plan if you have an iphone, which you would not have to pay with some other phones that will also text and play music well. I cannot recommend a alternate phone however, someone else will have to chime in. Good luck!
    Game Room 5.1.4:
    Bedroom 2.1
  • xj4094dg
    xj4094dg Posts: 1,158
    edited May 2010
    Wait for 4G.
    "The good thing about science is that it's true whether or not you believe in it." Neil deGrasse Tyson.
  • donahue
    donahue Posts: 125
    edited May 2010
    The refurb from AT&T requires both a new 2 year contract as well as the $30/month data plan. I was trying to avoid both. I just want to take the sim card out of her existing phone and put it in an iPhone that I purchase off eBay or buy used from someone.
  • Willow
    Willow Posts: 10,999
    edited May 2010
    donahue wrote: »
    You can do that. If the phone is unlocked you can use it from any carrier.
  • rooftop59
    edited May 2010
    OK, you can go that route but you have to jailbreak the phone and replace the sim card. This is not for the technological faint at heart, and could possibly brick the phone. Here are a couple of links to get you started:
    http://www.maclife.com/article/how_to_remove_the_iphone_sim_card
    http://www.appleiphonereview.com/iphone-tutorials/iphone-jailbreak/
    Good luck!
    Game Room 5.1.4:
    Bedroom 2.1
  • bobman1235
    bobman1235 Posts: 10,822
    edited May 2010
    If you don't get the unlimited data plan I promise you you're going to get NAILED with your first bill on data overages. No matter how much she says she won't use it... it's so integrated that i's impossible NOT to use it.
  • cstmar01
    cstmar01 Posts: 4,424
    edited May 2010
    the only thing though too is watch out. if your getting an iphone and she wants to use the internet on it, your going to have to pay for the service (normally) so depending on what she is doing and decides to go on the net (in a non wi fi area) your probably going to get charged.
    I have an iphone 3GS and think its like the 32 gig one or whatever. good phone, buy a case though too as they don't like to be dropped, not even once.
  • Willow
    edited May 2010
    cstmar01 wrote: »
    I was thinking of doing the same for my Itouch as they are so easy to drop and break.
  • nebborjk
    nebborjk Posts: 425
    edited May 2010
    I recently purchased a used iphone 3G for my daughter off ebay. Jailbreaking and Unlocking takes all of 5 minutes using the blackra1n software. I'm not sure how anyone could screw up this process it's so easy. I don't have a data plan for her phone. She uses the home wifi connection for internet access. When she out of range for the wifi she's SOL.
    Proud SOPA Member since 2005!
  • bobman1235
    edited May 2010
    Blackra1n does not work for the most recent (3.1.3) version of the iPhone firmware, and jailbreaking is considerably more difficult. Last I checked there were issues with unlocking newer firmwares as well.
  • nebborjk
    nebborjk Posts: 425
    edited May 2010
    Your correct. Blackra1n only works with v3.1.2.
  • Toxis
    Toxis Posts: 5,116
    edited May 2010
    And blackrain didn't work when I did the 3.1.2 upgrade but I found a different method. Just research everything. Find other ways to get the phone on 3.1.2 or even 3.1.3 unlocked and jailbroken. It's not hard either way. I have a 8gb 2g on tmobile and love it. No data plan, wifi is everywhere, and it's a lot better phone than most. Do it, she'll love you forever. But then You'll want one.
  • greg2350
    greg2350 Posts: 544
    edited May 2010
    Toxis wrote: »
    Used to be alot better phones than most I can name many that are out now that well just are alot better than the iphone for many reasons. My brother has a 3gs and my sister has the samsung Memoir, I played with both for 30 minutes the memoir hands down was a much better phone in every way. There was nothing I liked about the iphone that was better than the memoir not to mention the 8.0 megapixel camera on the memoir. Let me save you a reply yes I know its a personal taste.:)
    TV: Philips 42" LCD 1080p
    Front Speakers: Polk Audio RT800i
    Center Speaker: Polk Audio CS1
    Surround Speakers: Polk Audio R50's powered of Denon AVR
    Subwoofer: Polk Audio DSW pro500
    AVR: Denon 3801
    DVD Player: Denon DVM 745 upscale 1080p
    Sat: Directtv HD 10
    Front Speakers Amp: Rotel RB 890
    Center Speaker amp: Rotel 970 BX
  • Toxis
    Toxis Posts: 5,116
    edited May 2010
    True but by "most" and you bring one phone as an example... I said MOST. I'd still take it over most android phones just due to the flexibility of accessories. Find me another phone that can be used as an MP3 player with a direct plug to my OEM Honda radio or a docking station I can use at my work (I work in home theater). All the android fans have to bring in a mini to RCA cable. No thanks.
  • bobman1235
    edited May 2010
    Haha, that's kind of amusing. "Find another phone that uses a proprietary jack that has been widely used; all other phones use a standard non-proprietary jack. Rubes!"
  • mdaudioguy
    mdaudioguy Posts: 5,165
    edited May 2010
    I've had my iphone for a year. We have a love/hate relationship. :)/:mad:
