Polk RM 6700 threaded insert
gmdphd
Does anyone know what size screw fits into the threaded inserts of the Polk RM 6700 satellite speakers?
(Length, width, pitch....etc.)
Thanks.
Thanks.
Polk RM 6700
PSW 303
Sony STR-DE485
PSW 303
Sony STR-DE485
Post edited by gmdphd on
I dont know off hand, but the omni mounts worked perfectly. i you might check the size screws they use. ps i love my 6700.
I'm sorry this isn't a total answer, but you could do what I did, take your satellite for a walk into Home Depot bolt aisle, in 30 seconds I found the right one
The threaded insert on the back accepts a 1/4" x 20 bolt.
Hope this helps! I am on my way to the store now to buy a few for my speakers.My Home Theater System:
_____________________
Yamaha HTR-5280 Receiver
Mitsubishi DD-8040 DVD w/DCDi
JVC SVHS HR-S46004 VCR
Panasonic CT-32HL43 HDTV Monitor
Polk Audio PSW450 Powered Sub
Polk Audio RM-6700 Sat System
