SR104 Grill
pioneercrazed
Hi there,
I just recently bought a Polk SR104-DVC and built a custom fiberglass enclosure for it and have the subwoofer mounted flush. I'm looking for a grill that will fit perfectly and use the holes of the SR104 if possible. It doesn't look like Polk makes a grill for the SR series unfortunately but they do for the MM series, has anyone tried on of these grilles on their SR subwoofers?
http://www.amazon.com/Polk-Audio-AA0110-10-Inch-Grille/dp/B001C3R43K/ref=sr_1_7?ie=UTF8&s=automotive&qid=1272931123&sr=8-7
Post edited by pioneercrazed on
For future reference this works, I ordered one an its a perfect fit.
