Need to repair a MW surround
falconcry72
falconcry72 Posts: 3,580
edited May 2010 in Vintage Speakers
I finally found a great local pair of SDA-2B's which will be a part of my first "real" 2-channel system.
They only have one problem: One of the dimensional drivers (MW6511) has a very small hole in the rubber surround; it looks like a needle punctured it. Air leaks out of it when I push in the passive, but it works.
I'd prefer to replace it, but I know these are rare.
I think I may be in luck because of how tiny the hole is, but I'm not sure what to use to seal it. Rubber cement? I want to get some feedback before making it worse.:)
I'll post pics of the repair as I go along to help for future reference.
Post edited by falconcry72 on
  • falconcry72
    edited May 2010
    I found something that may work. It's made by Loctite, and it's called "vinyl, fabric, and plastic flexible adhesive."
    Here are some excerpts from the package:
    -for mending rips and tears in all flexible materials
    -waterproof, clear, durable
    -bonds: seats, clothing, shoes, fabric, canvas, rubber, leather
    -adhesive is highly flexible to withstand bending and torsion
    I'm letting some dry on a piece of paper right now to see how it cures. If it looks alright, and I haven't heard "don't do it" by anyone here, I'll be trying it on the driver when I get off work.
  • Schurkey
    Schurkey Posts: 2,104
    edited May 2010
    "I" would apply the stuff with a needle, so the glue is inside the hole, plugging it. Seems preferable to just blorting a patch over the hole and surrounding area.
  • falconcry72
    edited May 2010
    Schurkey wrote: »
    good idea. It really is a tiny hole, so I'm thinking 1/4 of one drop should do it; I just hope it doesn't get blown out of the hole when I crank'em!:rolleyes:
  • ben62670
    ben62670 Posts: 15,969
    edited May 2010
    I used a piece of gauze once before as a backing material to fix one. For adhesive I used rtv black. Also Polk carries the replacement;)
    Ben
    F1nut Posts: 50,755
    edited May 2010
    falconcry72, take the driver out of the cabinet and apply the repair material to the backside of the surround.
    Ben, I found that RTV doesn't stick very well to the surround.
  • falconcry72
    edited May 2010
    The paper test went well; the loctite dried into a soft, strong, flexible and clear rubber-type of substance. It stretches to about 3 times its dried length, but it is very strong and takes a lot of force to snap it. It adhered well to the paper, but I'm not sure how it'll do with the butyl rubber surround, though the box indicates that it's good for rubber. I was very impressed by the combination of flexibility and strength.:)
    I went ahead and applied the loctite to the surround. I used about 1/2 of one drop, only on the inside. If it doesn't hold when played loud I'll add a little more to the back side as well as to the front.
    See pics. I was working in my "dirty studio". I have a dirty studio and a clean studio for different types of work. Those are KRK Rokit 8 powered studio monitors that I use with my ipod. There is usually a fan or two on in that room, so super hi-fi is pointless. Those Rokits are solid monitors, though. The 2B's will live in my clean studio.:cool:
    I'll give an update when it's dry and I've had a chance to run them loud. That won't be until Wensday evening- I've got a new (to me) amp and preamp on the way.:D
    F1nut Posts: 50,755
    edited May 2010
    Excellent info, thanks for sharing.
  • Cthulhu11
    Cthulhu11 Posts: 69
    edited May 2010
    Polk still carries the MW6511, matter of fact they have it in stock the drivers usually run about 60 buck a piece new.
  • jrgoswick
    jrgoswick Posts: 159
    edited May 2010
    I'd go ahead and get another one from PCS(have it en route), and try to fix the other one for an ohh-crap spare. That's just me though. Either way, POST RESULTS, you're not the only one that has had this happen.
    Onkyo TX-SR705 AVR
    Onkyo M-501-Given to my father.
    Onkyo DX-C730 CD Changer
    Onkyo DV-BD507 Blu Ray player
    Onkyo CP-1036A turntable with Grado, Audio Technique, and Azden cartridges(GOT CARTRIDGE??)
    Polk Monitor 12's with RDO's and XO's
    Polk CS300 Center
    Polk Monitor Series 4 rears
    EBAY is like cocaine. At first you only look, next thing you know, your house is full of crap you have no idea why you own.:eek:
  • tx_polkhead
    tx_polkhead Posts: 248
    edited May 2010
    Nice fix, looks like it should hold. I was looking for just that type of material, While pulling a MW from a M7 I slipped and stabbed a small hole in the rubber surround. My hole is more like a flap! Funny thing is after I replaced the driver and didi the PR seal test, it holds long and tight! Someday I'll either repair like you did or replace the driver.
    Polk Audio RTA 12c's, Monitor 7c, Monitor 5JR+, SDA CRS+
    heiney9 Posts: 25,217
    edited May 2010
    How's it working out ?
  • falconcry72
    edited May 2010
    heiney9 wrote: »
    So far, so good!:D I cranked it good and stong last night, and as far as I can tell it's holding air 100%. There are no sonic differences that I can perceive, but I'd imagine they are there to some degree. I'm still going to keep an eye out for a used 6511, but I'm not going to buy a new one as long as this holds.;)
    If it fails I'll update this thread.
  • falconcry72
    edited May 2010
    jrgoswick wrote: »
    Yea, I know I'm not the only one. I do have a bad memory, but I didn't post the pics for my own reference.:cool:
