RDO 198s
sda2mike
sda2mike Posts: 3,131
edited May 2010 in Vintage Speakers
i just recieved a pair of rdo 198s for a TL upgrade on my SDA2Bs...can anyone point me in the right direction for the tweeter connections? the 198 tabs are larger than the sl2000 or rdo 194 tabs.
thanks
mike
Post edited by sda2mike on
  • zarrdoss
    zarrdoss Posts: 2,562
    edited April 2010
    parts express, radio shack
  • Schurkey
    Schurkey Posts: 2,104
    edited April 2010
    Or solder the wire to the terminal, and use a normal-size disconnect in-line somewhere.
    I bought some smaller-than-usual push-on terminals; but even those were too large.
    heiney9 Posts: 25,217
    edited April 2010
    Are you asking which is + and which is - or are you looking for the actual connector's?
  • sda2mike
    edited April 2010
    actually, H9, i was eventually going to ask the polarity question...when i went with 194s, i just did it by ear, more or less..one cabinet has blue and white wires while the other has black and white,,,the ser #s are close too..
    and yes, my original question was about the connectors going to the 198s
    thanks
    mike
  • dbaldus
    dbaldus Posts: 730
    edited April 2010
    If you're not going to use your old SL2000 connections, is there any chance I could have them? When I received my SDA SRS's, they were missing some of the stock connections and I'm always afraid the new ones (which are too big) are going to come undone.
    If you're planning to use them for something else, no worries, but I figured it would be worth asking!
    2-channel
    Squeezebox Touch| MSB Analog DAC | Audio Research Ref 40 Anniversary Edition| Pass Labs X350.8 | Wilson Audio Sasha 2
    Arcam AVR 550 | GoldenEar Triton One | GoldenEar SuperCenter XXL | GoldenEar Aon 3 | JL Audio Fathom F113v2
  • sda2mike
    edited April 2010
    dbaldus wrote: »
    i see no problem with that! PM me yer perticklers:cool:
  • fafner
    fafner Posts: 115
    edited April 2010
    heiney9 wrote: »
    So tell us, which is + and which is - ?
    fafner
    Fronts - Polk SDA2B's
    Center - Polk 350CS
    Surrounds #A - Another pair of SDA2B's
    Surrounds #B - Another pair of SDA2B's
    Rears - Yet another pair of SDA2B's
    Subwoofers - 2 M&K's
    AVR - Denon 3808CI
    Display - Sony 52KDL4100
    Blu-ray Player - JVC BP-1
    HTPC - Self built - Intel Quad Core I7 920@4.0ghz
  • george daniel
    george daniel Posts: 12,096
    edited April 2010
    black/blue =positive
    Toolfan66 Posts: 17,336
    edited April 2010
    And the wide terminal = positive
    Polk Audio SDA 2.3tl Fully Hot Rodded. 😎
    SVS SB16 X2
    Cary SLP-05/Ultimate Upgrade.
    Cary SA-500.1 ES Amps
    Cary DMS 800PV Network
    Jolida JD9 Fully Modified
    VPI MW-1 Cyclone RCM
    MIT Shotgun 3 cables throughout / Except TT, and PC’s
  • inspiredsports
    inspiredsports Posts: 5,501
    edited May 2010
    Mike,
    Posts #54, 61 and 62 at http://www.polkaudio.com/forums/showthread.php?t=74945 have some images and information that might also help you out.
    P.S.: Toolforlifefan . . . it was my impression back when I did the mod (and the schematics back me up) that the wider lug (white) on the RDO-198 is the negative lug and black (smaller) is +. Did I misinterpret?
    Conrad Johnson PV-5 w/mods
    MF x-DAC V8, HAInfo NG27
    NAD SS rigs w/mods
    GIK panels
  • Conradicles
    Conradicles Posts: 6,138
    edited May 2010
    I would guess somebody did it wrong lol.
  • sda2mike
    edited May 2010
    thanks for the replies, everybody....on the rdo198, the smaller tab is painted red...wouldn't that indicate positive???
  • george daniel
    edited May 2010
    IIRC--yes
    black should be +
  • inspiredsports
    edited May 2010
    sda2mike wrote: »
    As in my post above for my SDA-2B TL's, and also on my TL modded SDA SRS 2's, . . .
    . . . Red Painted RDO-198 Tab = + = Black Wire . . . has worked perfectly for me.
    NAD SS rigs w/mods
    GIK panels
    edited May 2010
    No nobody did it wrong;) I was just seeing who was on there toes..:D
    The wide terminal is your negitive..
    SVS SB16 X2
    edited May 2010
    That is correct otherwise you would be out of phase.. My 1.2's were wired out of phase at the crossovers when I got them, they sounded just fine I never looked at it when I got them till someone here pointed it out and as far as I know there were 3 of us that had that same issue..
    SVS SB16 X2
  • hearingimpared
    hearingimpared Posts: 21,136
    edited May 2010
    Believe it or not that is not an uncommon occurance.
  • Schurkey
    edited May 2010
    Strangely enough, Polk has the tweeter polarity reversed on some models. The + post of the tweeter is actually connected to the - section of the crossover. The schematics bear this out.
    Examples, from http://www.polkaudio.com/forums/showthread.php?t=55888 post #5
    2.3TL (but not the 2.3)
    1.2TL (but not the 1.2) (best example, shows color codes)
    There may be others, I didn't do an exhaustive search.
    Go figure.
    Polk still used the white wire/colored wire pairing for the tweeters; the white wire is now the "powered" wire but goes to the - terminal. The colored wire--which in most of the other models is the "Powered" wire--connects the tweeter + terminal to ground. (In short, it seems that no matter what speaker model you have, a white wire goes to the - post on the tweeter, the colored wire (black is considered a color) goes to the + post, the + post may or may not be painted red.)
    With regard to the "reverse polarity" speakers...HOW a person is supposed to keep those white wires in the correct positions is beyond me. The color code is--obviously--the same, yet each white wire carries a different (frequency/amplitude modified) signal depending on tweeter position. The colored wires which would be easy to keep in correct position...all go to the same place (ground).
    This makes not a damned bit of sense to me; but there it is on the schematic, big as day. Maybe someone will confirm that there's an error in the schematics.
  • sda2mike
    edited May 2010
    gotta keep this thread open before i committ to the snip snip:)
  • ben62670
    ben62670 Posts: 15,969
    edited May 2010
    The positive terminal is reversed on a few of the SL3000 SDA's because they are 3rd order XO's on the highs and 2nd order on the lows.
    Ben
  • Schurkey
    edited May 2010
    sda2mike wrote: »
    thanks
    mike
    When I installed the 198s into my 1Bs, there was a terminal on the 198 tweeter that fit the existing wiring, and a terminal that was way too small for the existing wiring.
    You're saying that one terminal is too LARGE on the 198 to fit your wiring???
    What are the widths of the terminals you're working with?
  • sda2mike
    edited May 2010
    Schurkey wrote: »
    No...you're right.....the tab that's red is too small. the other fits the existing female connector on my 2b
  • inspiredsports
    edited May 2010
    Lets put this to bed with the facts.
    Image of backside of RDO-198 (replaces SL-3000) with smaller (red painted) positive terminal (generally black wire) and wider negative terminal (generally white wire).
    The RD0-194 (replaces SL-2000) has the smaller terminal on BOTH plus and minus poles.
    I soldered a (1/8" to 1/4"?) female lug (seen at bottom of photo) from Radio Shack to my negative wire to keep it plug and play.
    NAD SS rigs w/mods
    GIK panels
  • sda2mike
    edited May 2010
    thanks, i.s.! my 198s are plain, no writing, on the magnet. the small terminal is red though...
  • sda2mike
    edited May 2010
    ya got me thinkin, I.R.,...........i wonder if anyone has a female to male adaptor for the 198 small terminal??
  • sda2mike
    edited May 2010
    :D
    well it's a proud moment!:p my step-son has a soldering iron, so i got all brave! i did it my 1st! it's kinda cool, too! i like the soldering feel:) anyway, thanks for all the helpful polkforum help...my Xover's should be home this week!
  • WastelandWand'r
    WastelandWand'r Posts: 466
    edited May 2010
    SDA2,
    I think inspired added the text to that photo for us 'visual' type of people who have a hard time drawing a mental picture from words alone.
    Have fun with the soldering and enjoy the new tweets.
    Nathan
    Home Rig
    SDA 2.3TL's front and center
    Polk 1000p Center
    Pioneer Elite SC35 Receiver (Pre/Surround
    Sunfire Cinema Grand 5X200-Back in the mix.
    OPPO BDP-93
    Squeezebox
    Stepped up to name brand Speaker Cables and interconnects!
    Monitor 4, 5, 7, 10's, SDA 1B's, 2B's, 2.3TL's, RTA 15TL's all in storage waiting for me.
    Sales Rating #1!!
  • inspiredsports
    edited May 2010
    . . . I think inspired added the text to that photo . . . Nathan
    Correct, the back of the RDO-198 has no writing . . . I added the text with an image editing tool to illustrate what's what.
    NAD SS rigs w/mods
    GIK panels
  • sda2mike
    edited May 2010
    Ha! now that's a frkn riot!
