2 channel receiver with a sub output?
yepimonfire
yepimonfire Posts: 256
edited April 2010 in 2 Channel Audio
im considering getting a 2ch receiver for music but i want it to have a sub output and an electronic x-over in the receiver. ive seen a few, but most of them cost alot more then i want to pay.
Post edited by yepimonfire on
  • coolsax
    coolsax Posts: 1,826
    edited April 2010
    check out Harman Kardon's ebay store
    they sell factory refurbs of 3380-3390 80wpc@8ohm 100wpc@4ohm and 3480-3490 120wpc@8ohm and 150wpc@4ohm 2 channel receivers. you can generally get them for between $150-$400
    Main 2ch -
    BlueSound Node->Ethereal optical cable->Peachtree Audio Nova 150->GoldenEar Triton 2+
    TT - Pro-ject Classic SB with Sumiko Bluepoint.
    TV 3.1 system -
    Denon 3500 -> Dynaudio Excite 32/22
  • AsSiMiLaTeD
    AsSiMiLaTeD Posts: 11,728
    edited April 2010
    The HK in my sig has what you're looking for and is a great receiver, check it out
  • Danny Tse
    Danny Tse Posts: 5,206
    edited April 2010
    Onkyo TX-8555
    100 watts/channel, x-over is at 80Hz (confirmed by Onkyo) and under $200.00 when purchased refurbished @ accessories4less.com (Onkyo authorized)
  • Erik Tracy
    Erik Tracy Posts: 4,673
    edited April 2010
    If this is just for 2-channel, why not drive the sub from speaker level inputs and use the sub x-over to integrate with your fronts?
    I can't imagine that there would be any "scary LFE" to worry about for music for your mains and the sub x-over would offer infinitely better control over fine tuning the x-over freq.
    It sure would open up more possibilities for a good deal on a used receiver.
  • comfortablycurt
    comfortablycurt Posts: 6,745
    edited April 2010
    It's not a "receiver" exactly...but the Parasound NewClassic Model 2100 is a 2 channel pre-amp, that has built in bass management.
    The nirvana inducer-
    APC H10 Power Conditioner
    Parasound Halo P5 preamp
  • DaveHo
    DaveHo Posts: 3,545
    edited April 2010
    The Outlaw reciever also has analog bass management. Might be a bit more $$ than you want to spend though.
    -Dave
  • dkg999
    dkg999 Posts: 5,647
    edited April 2010
    NAD C720BEE. Sub output with fixed cut-off at 100hz IIRC. You can get refurbed units pretty cheap if you can't find a used one. Great sounding 2 ch receiver, and yes I own one.
    DKG999
  • yepimonfire
    edited April 2010
    Erik Tracy wrote: »
    subwoofers only have a low-pass filter, not a high pass which means im still sending LF information to the fronts which pretty much ruins the idea of having a 4-way system. correct me if im wrong but the psw10 sub from polk has no high pass correct? i have a receiver, but its just straight 2ch unfiltered sound, i really would rather not buy a new receiver if there is another fix for this. oh and i saw someone mention a 2ch preamp, i didnt know it was even possible to get those these days, only pre-amps i have been able to find cost me 700 dollars minimum and are full of all kinds of bells and whistles i dont need they are built for surround sound and digital audio processing. ive been wanting to set up a pre-amp type system for while now and use a seperate amplifier but have had no luck finding a pre-amp.
    atm i am using my 7ch receiver for 2ch stuff because it has an active crossover. would like to put it back into my living room haha
  • camp21178
    camp21178 Posts: 273
    edited April 2010
    Erik Tracy wrote: »
    Thats what I do, let the sub carry the bass and the fronts carry the mids and treble.
  • Erik Tracy
    edited April 2010
    Again - if this is for music - what is the fretting and hand wringing all about for sending full audio signals to your mains?
    In the ancient distant misty past of yore for 2-channel, folks were happy and rejoiced at the joyous sound they could get from their 'full range' speakers.
    The scary LFE Monster had not yet been born to instill fear of straining their poor amplifiers or subject their bookshelf woofers to the woes of burdensome bass.
    [tongue in cheek guys...:p;):D]
  • yepimonfire
    edited April 2010
    actually most people are afraid of LFE ruining their bookshelfs even when in reality this isnt an issue, i used to have a 7 channel system used for movies and i drove the LFE through my bookshelfs and it wasnt an issue.
  • curved
    curved Posts: 664
    edited April 2010
    Your bookshelves will only play down to what they are capable of.....I'm sure you were missing a lot of low end with them.
    Why not get a pre that has dual rca outputs and send one set to your amp and the other to your sub?
    Living Room:....................[HTML] [/HTML] Zone 2 (Workout Room):
    AVR - Yamaha RX-V757......JBL 4312 Pro Monitors
    Pre - Nak CA-5
    AMP - Adcom 555 (Main)
    Main - Polk RTI8**/RTiA5
    AMP - Adcom 545II (Center)
    Center - Polk CSiA4**
    Sub - Snell Basis 300:p......Zone 3 (Outside)
    CD - Yamaha CDC-555.......Def Tech AW5500
    TV - Pani TH-42PZ80U
    BR - LG BD390
    Monster HTS1600 Power Center
    Dedicated Circuit - (2) 20amp, (1) 15amp
    Ben's IC, Canare 4S11
    **Dayton and Sonicap Caps with Mills Resistors**
  • yepimonfire
    edited April 2010
    yes i know i was, but the point is people are constantly scared they will destroy their bookshelves with LFE. and if anybody would give me a link to where i can buy a 2ch pre-amp that would be great, i have been trying to find one for some time now.
  • curved
    curved Posts: 664
    edited April 2010
    www.audiogon.com is a great place to start looking. I would keep on eye on the forum here because there are great deals on a daily basis.
    Pre - Nak CA-5
    BR - LG BD390
  • Erik Tracy
    edited April 2010
    +googolplex!
    :D
