Audio ****
cbl117
Went through an upgrade spell and took some pics now that its finally finished. Enjoy!
Vandersteen 3a Sigs
Music Reference RM-200
Hovland HP-100
VPI Scout w/ Benz Ace
Rotel RCD-1072
Cardas Golden Reference Speaker Cables
Cardas Golden Reference Interconnects
Cardas Golden Power Cords
PS Audio UPC-200HB
Black Diamond Racing Isolation
Vandersteen 3a Sigs
Hovland HP-100
Rotel RCD-1072
PS Audio UPC-200HB
Post edited by cbl117 on
Very nice setup. I've never noticed before how much those Vandersteen's resemble SDA-1C's. I want your turntable.SDA-1C (full mods)
Carver TFM-55
NAD 1130 Pre-amp
The Clamp
Nakamichi CR7 Cassette Deck
Cambridge Audio DACmagic Plus
ADC Soundshaper 3 EQ
Ben's IC's
Nitty Gritty 1.5FI RCM -
Love the cable elevators. lol. no system is complete without them.
Nice setup man. i am jealous for sure.Front - RTiA5's
Rear - RTiA3's
Center - CSiA4
Sub - PSW110 -
packetjones wrote: »Love the cable elevators. lol. no system is complete without them.
Lol...thanks. They were free too! Took some foam from work and cut two slots in each to guide the R & L channels. Very slight difference in sound...it adds resolution which makes some recordings sound better while making other recordings sound a tad sterile.2 Channel
Vandersteen 3a Sigs
Hovland HP-100
Rotel RCD-1072
PS Audio UPC-200HB
Black Diamond Racing Isolation -
Very, very nice Bro! Of course my eyes went immediately to your turntable.
Nice system, love the turntable!!
badA$$ rig for sure bro. Nice gear.Shoot the jumper.....................BALLIN.............!!!!!
Very nice setup!!!
What's with the cover on the TV? **** image burnt into the screen, and you didn't want us to see it?:p;)I've never noticed before how much those Vandersteen's resemble SDA-1C's.
+1
I actually thought they were 1C's until I read your post...lolThe nirvana inducer-
APC H10 Power Conditioner
Parasound Halo P5 preamp
comfortablycurt wrote: »Very nice setup!!!
Ha! No ****. It kills the early reflections coming off the glass screen. It does wonders for the image focus. If your as unlucky as I am and have a giant **** TV in between your speakers you should give it a try. I bet you'll always do critical listening with a blanket over your TV!2 Channel
Vandersteen 3a Sigs
Hovland HP-100
Rotel RCD-1072
PS Audio UPC-200HB
That is audio **** for sure! Sorry you have to live with that wall behind the couch, I used to have the same situation. Its really hard to deaden without deadening too much and making you uncomfortable.Vinyl, the final frontier...
Yeah I know what you mean. There is about 8" between the rug and the couch and figure another 8" from my head to the back of couch. I'm about a foot and a half from the wall...still not nearly far enough. The rug helped alot. Without it, the image was a mess and the sound was fatiguing. I still have some energy coming from the corner behind me/next to rug. I'm considering an absorption panel mounted at 45 deg.2 Channel
Vandersteen 3a Sigs
Hovland HP-100
Rotel RCD-1072
PS Audio UPC-200HB
What is the stand you have your table on? I like it!Vinyl, the final frontier...
Unfortunatley my in my room my couch is up against the back wall. The couch is overstuffed and I have wall-to-wall carpeting in the room. I take some throw pillows and line them up across the top of the couch to tame the splash back off that back wall. It worked out pretty well except my wife keeps taking them back to place on the couch on the living room where they belong . . . UGH! Women! -
The rug provides great diffusion and also looks great. Where did you get the bar that holds the rug? I'm looking for the same.HT in Progress
Receiver - Harmon Kardon AVR520 5.1
Fronts - Polk SDA 1C
Center - Polk CS350
Monitor - Sharp Aquos LCD
NMT - Mede8er500x
Cables - Signal Ultra -
Its a bright star audio sand box. Custom made for a VPI TNT HRX...there's a separate top peice for the motor assembly. Doesn't quite work for the scout's motor so I'm going to make a new top so the motor is isolated from the rest of the plinth.
The rod holding the carpet is made of solid maple and I think was picked up at an arts n crafts store...michaels?2 Channel
Vandersteen 3a Sigs
Hovland HP-100
Rotel RCD-1072
PS Audio UPC-200HB
Oh my, you just made my heart skip a beat! BTW do you know what kind of sand is being used in the sand box? -
hearingimpared wrote: »Oh my, you just made my heart skip a beat! BTW do you know what kind of sand is being used in the sand box?
No clue. It was my friend's rack. He sold his HRX for a (heart will stop) grand prix audio table. I do know the sand is very fine.
Heres some more info on system:
The rack legs are filled with lead shot.
The PS audio power conditioner is also on a bright star audio sand box.
All components are resting on black diamond racing cones. Mk3 for CD player and Mk4 for amp and preamp.
Not sure if you guys noticed, but there is an absorption panel on the side wall. Its a GIK Acoustics 242 panel.
Oh and most importantly...gold lion kt88s in amp and tele smooth plates and amperex bugle boys in the pre!2 Channel
Vandersteen 3a Sigs
Hovland HP-100
Rotel RCD-1072
PS Audio UPC-200HB
The reason I was asking about the sand is that a lot of people just buy regular (seashore) type sand and it has a propensity to gather from the air any moisture, especially if you live in an area with high humidity, and then it gets moldy which is hard to get rid of. Reptile sand is the best in these applications as it repels moisture.
Black Diamond Racing Cones are execellent. I use the MK4s under my turntable in conjuction with Isol-Pads and they really are impressive for isolaton and add a nice bit of warmth to the sound . I would have them under all my compenents especially the BDR pucks but for the now the cost is prohibitive. I use Isol-Pads from Quest for Sound under all the rest of my gear which do a really good job of isolating the components for air borne and rack vibrations as well as resonance but I would love to get the BDRs and use them in conjunction with the Isol-Pads as it really does a nice job on my TT.
You've got a really nice rig going there Bro.:) -
I appreciate the feedback guys.:)2 Channel
Vandersteen 3a Sigs
Hovland HP-100
Rotel RCD-1072
PS Audio UPC-200HB
Very nice looking!
I have the BDR pits under my speakers and subs and they are great piece for decoupling.
These were the only pieces I've ever bought where my wife questioned my sanity She couldn't understand why I paid so much for hockey pucks!
Gordon2 Channel -
Symposium Rollerblocks 2+ (16)Black Diamond Racing Mk 3 pits (8) -
I had some of those Vandy's! I have loved Vandy since they introduced the 2C! (the vandy 2 and 3 represent top notch music for a reasonable price compared to the competition.) -
Is that a Persian rug or just cheap Lowe's version?TNRabbit
NO Polk Audio Equipment :eek:
Sunfire TG-IV
Ashly 1001 Active Crossover
Rane PEQ-15 Parametric Equalizers x 2
Sunfire Cinema Grand Signature Seven
Carver AL-III Speakers
Klipsch RT-12d Subwoofer -
It is a persian style rug, but was it hand made by an Iranian?...No. It's woven wool and wasn't cheap!2 Channel
Vandersteen 3a Sigs
Hovland HP-100
Rotel RCD-1072
PS Audio UPC-200HB
