bi-amping?
i4gotmyid
Question for you guys, I have a yamaha reciever with pre-outs and I have sda2.3 speakers. I would like to by two amps to bi-amp them as everyone says its better, but I have a couple of questions.
If i get two 100 watt/channel amps how do i connect them to my receiver? Do i split the signal from the pre-out using a Y-cable/adapter?
Is 100watts per channel bi-amped equal to power of a 200 watt amp driving the speaker bi-wired?
What do i look for in an amp? What is the difference between high and low current power? Is one better than the other?
If i get two 100 watt/channel amps how do i connect them to my receiver? Do i split the signal from the pre-out using a Y-cable/adapter?Is 100watts per channel bi-amped equal to power of a 200 watt amp driving the speaker bi-wired?What do i look for in an amp? What is the difference between high and low current power? Is one better than the other?
Peace Out~:DIf...
Ron loves a film = don't even rent.
