My Phone Line Cut Again!!!
kevhed72
kevhed72 Posts: 5,046
edited April 2010 in The Clubhouse
The wonderful cable company cut our phone line AGAIN...this has been the
3rd time in as many years and each time the phone co. has come out and spliced the cut ends together with a black plastic box.
QUESTION---will these splices slow down my DSL and Netflix speed / or decrease picture quality?
Post edited by kevhed72 on
  • disneyjoe7
    disneyjoe7 Posts: 11,435
    edited April 2010
    I wouldn't think so, given the most wired pairs are spliced together to get near your house ;) Been a clean splice, the splice's should be ok.
    Speakers
    Carver Amazing Fronts
    CS400i Center
    RT800i's Rears
    Sub Paradigm Servo 15
    Electronics
    Conrad Johnson PV-5 pre-amp
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
    Sony CX400 CD changer
    Panasonic 42-PX60U Plasma
    WMC Win7 32bit HD DVR
  • bruss
    bruss Posts: 1,039
    edited April 2010
    I really doubt you would notice unless it wasnt done right
  • NotaSuv
    NotaSuv Posts: 3,849
    edited April 2010
    Lasareath wrote: »
    Been using a cell phone at home for the past 8 years. Maybe this is a sign.
    havent had a land line in almost as long.... the cell is the home phone
    well they say third times a charm...splices when done correctly will cause you no problem
  • Huck344
    Huck344 Posts: 453
    edited April 2010
    Why is the cable company cutting your phone line? And if they are cutting it, why aren't they fixing it?
  • Rivrrat
    Rivrrat Posts: 2,101
    edited April 2010
    Huck344 wrote: »
    Because they aren't authorized or even trained to repair telcom facilities. If I'm out and about and see a cable comany touching our plant, there will be major hell to pay.
    I'm assuming the "cable" is the drop to your house. If the drop splice is done right, you won't have any problem.
    My equipment sig felt inadequate and deleted itself.
  • danger boy
    danger boy Posts: 15,722
    edited April 2010
    tell them if they cut your line one more time you are dropping their ****.
    PolkFest 2012, who's going>?
  • kevhed72
    edited April 2010
    Good to know another splice shouldn't be a big deal. Most cables in our 'neck of the woods' of GA. are either buried a couple inches deep, or just laid on top of the ground....ie there are orange coax cables strung all over the place, which seems half-arsed to me.
