mm10 or mm12
Systems
Systems Posts: 14,872
edited May 2003 in Car Subwoofer Talk
im not into looks, i just want nice hard hitting bass. i was wondering how strong one mm10 or one mm12 in the polk/momo enclosure. i would probally by an alpine 600 watt amp, whould that blow the sub? thanx for you help
Testing
Testing
Testing
  • PoweredByDodge
    PoweredByDodge Posts: 4,185
    edited May 2003
    the polk momo subs are single 4 ohm coil -- the 10 can safely take 500 - 550 // the 12 can safely do upwards of 650+++ depending on the music -- they are underrated in some respects.
    a momo 12 in the polk enclosure with a bridged 2 channel amp that did 650 - 700 watts would adequately serve a smaller vehicle (2 door **** coupe car or a chevy cavalier... something that size).
    it would also do the job when placed in cabin (ie a pickup).
    but a decent sized SUV / or a larger car (lincoln town car...) would require two woofers or a single 1500 watt woofer.
    but that's just my opinion.
    The Artist formerly known as PoweredByDodge
  • Systems
    edited May 2003
    ok, thanks a lot, i was planning on taking out the shi pass behind the arm rest on a bmw 325i, thats why i would only want one, it would face right into the cabin. i have to do this because the trunks are sealed so tightly, once again thanx
    Testing
    Testing
    Testing
