Want to rebuild old speakers
PerfectCreature
PerfectCreature Posts: 1,456
I have a pair of old Vintage Pioneer CS-77A That I used to use when i was around 16 or 17. I recently found them in my Garage and wanted to recone the tweeter and fix maybe the crossovers? I may have to replace a woofer or two as well.
When I get home I can post picture of what they look like and what the damage is.
They will cut completely turn any receiver in to safe-standby mode i have ever tried them on once the volume is at half on any receiver. It doesn't matter how good the receiver is. It happens.
I'd really like to have these back and running again since they were amazing speakers. They had a 95db sensitivity and a 30-20k hz.Plus real Oak wood I believe. They were crazy.
If anyone has any ideas on how to fix these up it would be greatly appreciated.
These are the Specs I could find on them
- 4-Way / 4-Driver, "Infinite Baffle" / Air / Acoustic Suspension cabinet design
- Pioneers "F.B." design driver cones deliver more rigidity and lightweight performance resulting in quicker response and better mid-end with less distortion
- 30 cm / 12" "FB" (Free-Beating, wool impregnated pulp) Woofer
- 12 cm / 5" "FB" Midrange
- 7 cm / 2.75" "FB" Tweeter
- Multi-cell Super-Tweeter for less "beam" and greater dispersion over standard compression horns.
- "Real" 4-way crossover with crossover points @ 450 Hz, 3600 Hz and 14KHz.
- All Pioneer built components
- Dual 3-position Mid and Top-end Frequency level attenuators
- Push-button inputs
Specs:
Impedance: 8 ohms
Efficiency: 95dB 1w @ 1m
Frequency Response: 35-20,000 Hz, +/- 3 dB
Cross-over frequencies: 450 Hz, 3600 Hz and 10KHz
Power Rating: 65 watts RMS
Measure 25"h x 14.5"w x 12.5"d and weigh 45 lbs each
Receiver
Harman Kardon HK 3490
Speakers
Polk Audio Monitor 50s
Subwoofer
Klipsch KSW-100
Cables
AudioQuest Rocket 33s 10ft
AudioQuest Optilink1 2m
AudioQuest Alpha-Snake 25ft Interconnect
AudioQuest HDMI-1 2m
Alienware X51 R2
PS4
Samsung Smart TV 40" 1080p 3D
  • NotaSuv
    NotaSuv Posts: 3,871
    edited April 2010
    http://www.oaktreevintage.com/Pioneer_Speaker_Parts.htm
    good place to start.....email them for anything you might need, they will send you in the right direction....
  • PerfectCreature
    edited April 2010
    So they can help me with what I need?
    Are they trustworthy or whatnot I don't want to get burned like I have in the past.
    They said they didn't have any of my parts in. Only a few of them. And they are wicked expensive...
    Is there a way I could...like use the cabinet and maybe build a whole new speakers setup...anyone have any knowledge on that?
    Or maybe a cheaper parts store?
    Receiver
    Speakers
    Subwoofer
    Klipsch KSW-100
    Cables
    Alienware X51 R2
    PS4
  • greyford1979
    greyford1979 Posts: 749
    edited April 2010
    If you went with the just using the cabinets and completely rebuilding them route, one place you could check out is parts express. You can speak directly with one of their techs and help you through the process with everything you would need. Lot of their stuff has gotten pretty good reviews. I just recently bought one of their Dayton subs and bash amps from them and built an enclosure for it. It sounds absolutely amazing and for about a third of what it would have cost me to buy a completed sub of that caliber:D
    I love animals, they're delicious!
  • Conradicles
    Conradicles Posts: 6,437
    edited April 2010
    PartsExpress does have a lot of Pioneer drivers. May be a nice place to start.
    (or you could use all of that money to by some Vintage Polk Audio speakers!)
    heiney9 Posts: 25,724
    edited April 2010
    Just watch your $$$ as those Pioneer's aren't really worth putting money into from a listening/investment point of view. I realize they are sentimental and that's where the value lies. So don;t think your going to spend a lot of $$$ refurbing these and hoping to make your $$$ back, because you won't come close.
  • PerfectCreature
    edited April 2010
    True. I have the polk 50s and the sub...it's just that these used to be some gnarly speakers... I mean they were nasty. They shook the house and it was the kind of bass you felt in the chest...my 300 watt 12 inch 505 can't really make you feel it in your chest like these could...
    It is a real shame...
    So, parts express should be my first place to start?
    Anyone's suggestion on a money limit?
    Receiver
    Speakers
    Subwoofer
    Klipsch KSW-100
    Cables
    Alienware X51 R2
    PS4
