Best Forum resources for upgrading 1.2TL's
Binban
Binban Posts: 4
edited April 2010 in Vintage Speakers
Hello.. new forum member (however have been a long time owner of SDA 2.0's) that just picked up a pair of 1.2TL's here in northern CA. The pair with the slightly torn PR, and the broken binding post. Have been 'playing' with them for a week or so now and they sound like they are in pretty good shape overall, but I'm considering upgrading the tweeters and maybe the cross-overs depending upon how available parts might be these days. So my question is regarding who might be the best resource for starting to find some of the info I will need ... Anyway, looking froward to the project ! And thanks for any info the forum members might be able to share !
2-CH
Denon 5800
Polk SRS SDA 1.2TL
Hafler DH-500
Polk SRS SDA 2.0
Home Theatre
ONKYO TX-NR5007
OPPO BDP-83
PANASONIC PT AE3000U
PANASONIC PT AE1000U
SHARP Xv-z12000u
SHARP Xv-z9000u
Polk RT2000i
Polk fx1000
Polk fx500
Polk 650 Sub
Post edited by Binban on
  • leroyjr1
    leroyjr1 Posts: 8,785
    edited April 2010
    Welcome to the forum !!!
  • Binban
    Binban Posts: 4
    edited April 2010
    Thanks ! I should have joined long ago ...
    2-CH
    Denon 5800
    Polk SRS SDA 1.2TL
    Hafler DH-500
    Polk SRS SDA 2.0
    Home Theatre
    ONKYO TX-NR5007
    OPPO BDP-83
    SHARP Xv-z12000u
    SHARP Xv-z9000u
    Polk RT2000i
    Polk fx1000
    Polk fx500
    Polk 650 Sub
    F1nut Posts: 50,755
    edited April 2010
    There is no SRS SDA 2.0 model. Perhaps you meant SDA SRS2?
    Have you repaired the damage passive radiator?
  • Binban
    Binban Posts: 4
    edited April 2010
    Yes, you are correct (SDA SRS2) The speaker and tweeter pattern look just like the 1.2's (except only 4 speakers, two tweeters in the middle and of course the PR)
    We have tried a fairly simple repair on the torn rubber surrounding the PR (using rubber cement) to see how that will work. We were concerned that any kind of super glue would be too brittle, so decided to try the rubber cement first. Let it dry for a couple of days and it seems to be holding, but then again I haven't really pushed them too much yet. Trying to build a new set of interconnects at the moment. The pair that the seller had with the speaker were the two blades (not for the 1.2's), so I need to build or buy a new interconnect. Luckily, the interconnect fro the SRS2 is the same, so I have been able to test the 1.2's. 3rd issue will be replacing the broken binding post ... not sure where to start there yet, but will be checking old posts I guess ;>)
    2-CH
    Denon 5800
    Polk SRS SDA 1.2TL
    Hafler DH-500
    Polk SRS SDA 2.0
    Home Theatre
    ONKYO TX-NR5007
    OPPO BDP-83
    SHARP Xv-z12000u
    SHARP Xv-z9000u
    Polk RT2000i
    Polk fx1000
    Polk fx500
    Polk 650 Sub
  • toucanet
    toucanet Posts: 580
    edited April 2010
    Notes from Lasareath in a previous post:
    As per upgrading the crossovers:
    The below list provided to me from Joe Hearingimpared, So Thanks go to Joe!!!
    The following lists all the parts you need to buy for the crossover upgrade.
    Sonic Craft http://www.soniccraft.com/ ; Call to order, 501-620-4444, you will be speaking to Elliot.
    Sonic Craft Generation 1 http://www.soniccraft.com/sonicaps.htm
    “Sonic Capacitors Generation 1”
    Ask for Custom Matched & as close to 1% tolerance as possible:
    Qty Rating
    6 12uf (he was able to get the 1% tolerance for me)
    2 0.25uf (he is going to have problems matching this and will probably get within 8% tolerance which is okay.
    2 13.5uf (he could get 3% tolerance here for me)
    2 27uf (2% tolerance for me on this one)
    Mills Wirewound Resistors – non-inductive http://www.soniccraft.com/mills_resistors.htm
    All should be rated 12 watt
    Qty Rating
    2 2.7 Ώ
    2 7.5 Ώ
    2 11.5 Ώ (you may have to settle for 11 ohms here)
    2 15 Ώ
    2 22.5 Ώ (if you can only get 22 ohms that is okay)
    2 0.5 Ώ (to be used in place of the polyswitches)
    To summarize, you will be ordering 12 capacitors & 12 resistors
    It is going to cost you around $400 for all the parts plus shipping.
    You may want to buy a spool of Silver Solder as well.
    Sal
    __________________
  • Binban
    Binban Posts: 4
    edited April 2010
    Thanks much !!!! Should be a lot of fun assembling the new cross-overs. Last time I did much soldering was way back when i built my set of Hafler equipment (Amp, pre-amp, and tuner), way back in the 1980's ... SO this should be an adventure !
    2-CH
    Denon 5800
    Polk SRS SDA 1.2TL
    Hafler DH-500
    Polk SRS SDA 2.0
    Home Theatre
    ONKYO TX-NR5007
    OPPO BDP-83
    SHARP Xv-z12000u
    SHARP Xv-z9000u
    Polk RT2000i
    Polk fx1000
    Polk fx500
    Polk 650 Sub
