Building a CD Tower
bigaudiofanatic
I like a lot of the cd towers I see but decided I want to build one sense my dad is big in carpentry. "currently in Iraq" I was wondering what kind of nice wood people would recommend and what kind of stain. Also if anyone has any plans I can go by to get started that might be helpful.
I want it to hold cd's and dvd's and be at least 5ft tall and 6ft wide probably can be bigger. Any guidance would be helpful.
HT setup
Panasonic 50" TH-50PZ80U
Denon DBP-1610
Monster HTS 1650
Carver A400X :cool:
MIT Exp 3 Speaker Wire
Kef 104/2
URC MX-780 Remote
Sonos Play 1
Living Room
63 inch Samsung PN63C800YF
Polk Surroundbar 3000
Samsung BD-C7900
Denon DBP-1610
Monster HTS 1650
Carver A400X :cool:
Kef 104/2
URC MX-780 Remote
Sonos Play 1
Living Room
Samsung BD-C7900
Post edited by bigaudiofanatic on
Looking to make a CD rack of some kind this summer here. No plans yet.
Mahogany is the wood of choice for me, nice grain,stains even, semi- hard type that works easily. Finish will be varnish with a last final coat of urethane, sprayed.Parasound C1, T3, HCA-3500, HCA-2205A, P/DD1550, Pioneer DV-79avi, Oppo BDP-83, WD Media Server W/HDD,
Dynaudio Contour 3.3, Dynaudio Contour T2.1, Polk OWM3, Polk DSW micropro 1000 (x2),
Pioneer Kuro 50" Plasma, Phillips Pronto Control w/Niles HT-MSU. -
Nice I will look into that.HT setup
Denon DBP-1610
Monster HTS 1650
Carver A400X :cool:
Kef 104/2
URC MX-780 Remote
Sonos Play 1
Living Room
Samsung BD-C7900 -
My preference is cherry. No need to stain it. Use some light blonde shellac and the cherry will change color over time. I've built a coffee table, a dining room table and a stereo cabinet out of cherry and I think they came out pretty good.Front - Polk LSiM 705, Center - Polk LSiM 704c, Rear - Polk LSi 7
Subwoofer - Epik Legend
Receiver (as Preamp) - Sony STR-DA3400 ES
Amplifier - Outlaw 7125
Television - 58" Samsung Plasma PN58B860
Blu Ray - OPPO BDP 83 -
Do you have any pictures of them?HT setup
Denon DBP-1610
Monster HTS 1650
Carver A400X :cool:
Kef 104/2
URC MX-780 Remote
Sonos Play 1
Living Room
Samsung BD-C7900 -
I have some pictures but they are a meg and a half each. Is that too big to add to an entry? I also don't know how to do it.Front - Polk LSiM 705, Center - Polk LSiM 704c, Rear - Polk LSi 7
If you are using windows you can scale down the size of the pictures to use on the polk forum. Open the picture in paint and there you can resize them, I usually use the percentage scale and do about 25% of the original size and is usually fine. I have Win 7 and it has a resize icon in paint. I can't remember but I think in other versions you have to go into view or maybe skew in paint to resize?? As for posting the pics in the thread, at the bottom of the reply box there is a Manage Attachments button. Just click on that, use the browse feature to look for the pics and then upload, easy as that:D Just preview the post and they should show up and then you can submit the reply. Hope this helps. I guess I could have just linked the info but I need to practice my typing skills:DI love animals, they're delicious! -
Let's see if this works.Front - Polk LSiM 705, Center - Polk LSiM 704c, Rear - Polk LSi 7
I like your cabinet, did you build it yourself? It looks like a good sensible design.Larry
very nice!! I think I am going to take your advice. Any advice to get that shinny gloss finish.HT setup
Denon DBP-1610
Monster HTS 1650
Carver A400X :cool:
Kef 104/2
URC MX-780 Remote
Sonos Play 1
Living Room
Samsung BD-C7900 -
We have a woodworker amongst us, nice job!Parasound C1, T3, HCA-3500, HCA-2205A, P/DD1550, Pioneer DV-79avi, Oppo BDP-83, WD Media Server W/HDD,
Yep. I designed and built all three myself.Front - Polk LSiM 705, Center - Polk LSiM 704c, Rear - Polk LSi 7
bigaudiofanatic wrote: »very nice!! I think I am going to take your advice. Any advice to get that shinny gloss finish.
I used dewaxed blonde shellac ( 1 lb cut). I just made a pad out of cheese cloth wrapped in an old piece of t shirt. The pad was about the size of a ping pong ball. Dipped the pad in the shellac and spread it thinly. Came back in 15 minutes and did it again. By 6 or 7 coats it seemed finished to me. Easy to scrape off shellac if you get drips. Used a brush for the legs and underneath.
As long as you don't put alcohol on the finish, it holds up well. I wouldn't use it for a dining room table however. I used Behlen's rock hard varnish for that.Front - Polk LSiM 705, Center - Polk LSiM 704c, Rear - Polk LSi 7
Very nice!HT setup
Denon DBP-1610
Monster HTS 1650
Carver A400X :cool:
Kef 104/2
URC MX-780 Remote
Sonos Play 1
Living Room
Samsung BD-C7900
