CD burning
Vette C6.r
Vette C6.r Posts: 1,560
edited April 2010 in Electronics
Hey guys.
Not sure if this the correct section to post this but does burning a CD from Windows Media Player make a difference in sound quality.
Miller Lite Scott gave me a burned CD that sounds great and registers as a HDCD on CD player.
I'm sure this has been covered before but if I could burn some CD's that I want it would save me some serious coin.
Thanks as always.
TK
Post edited by Vette C6.r on
  • MillerLiteScott
    MillerLiteScott Posts: 2,564
    edited April 2010
    Tony I burned that CD just using iTunes lossless. Sal put a program on my computer that makes exact copies and I think it is called Nero.
    I have not really compared it to anything other than that Millage Gilbert cd was burned using nero and it sounds pretty good.
    I am sure Sal will chime in with all the info.
    Scott
    I like speakers that are bigger than a small refrigerator but smaller than a big refrigerator:D
  • hearingimpared
    hearingimpared Posts: 21,136
    edited April 2010
    I've used Windows Media Player 10 on super slow setting and am very happy with the results.
  • Vette C6.r
    edited April 2010
    Thanks Scott I will look into that.
    Joe I'm pretty sure that I have WMP 7 or 8 . How do you put it on super slow setting.
  • Face
    Face Posts: 14,340
    edited April 2010
    In settings.
  • hearingimpared
    edited April 2010
    Tony you should be able to get a free upgrade to WMP 10. To burn at best quality in 10, you go to the buttons under the menu bar and click the little arrow under "Burn". When the drop down menu is displayed you click "More Options." An "Options" dialog box will be displayed with serveral tabs you can choose from. First go to the "Burn" tab and under "General" you will see a drop down arrow where you can choose the speed. On mine it gives you four options on the drop down menu from "Fastest" to "Slow." Choose "Slow."
    Next go to the "Rip Music" tab. Under "Rip Settings" there is a drop down arrow. When the menu is displayed, choose "Windows Media Audio Lossless." Then at the bottom is a slide, move the slider all the way over to the right where it says, "Best Quality."
    I hope this helps.
    billbillw Posts: 7,797
    edited April 2010
    EAC (Exact Audio Copy) is what I use most of the time if I am looking for the best results. For quick copies, I use Nero set to 16x burn. BTW, EAC is free and Nero has a basic version that is free.
  • Vette C6.r
    edited April 2010
    Dang Joe is there anything you don't know.
    I tried to download MP10 and it says my there is something wrong with my windows copy.
    I will keep trying. Thanks for the info. Sounds like a pretty solid burn.
  • cfrizz
    cfrizz Posts: 13,415
    edited April 2010
    Be very careful downloading MP. The last time I upgraded mine, it rendered music that I bought online inoperable I lost 40 songs!
  • hearingimpared
    edited April 2010
    Vette C6.r wrote: »
    Are you kidding me? I wish I knew half of what most people in this club know. You just happened to catch me with something I did know.:o
  • hearingimpared
    edited April 2010
    cfrizz wrote: »
    Did it just overwrite everything Cathy? Are you sure it did't save the songs in a file somewhere that you may have missed during the upgrading process? It seems out-of-wack to me that it wouldn't save existing files.
  • cfrizz
    edited April 2010
    The songs were still there, they simply wouldn't play when clicked on. I would get an error message.
  • Vette C6.r
    edited April 2010
    Changed the setting on my MP - thanks guys. I will be burning away.
  • hearingimpared
    edited April 2010
    cfrizz wrote: »
    Maybe you need to associate those files with the proper extention that you have checked off in your WMP 10 options listing of recognizible formats.
  • hearingimpared
    edited April 2010
    Vette C6.r wrote: »
    Good deal Bro!
