Options for Receptacle for 2 Dedicated 20 amp circuit
rdb2001
rdb2001 Posts: 791
edited April 2010 in Electronics
Hey Guys,
I am having 2 20amp dedicated circuits put in next weekend. I wanted to know what are some good options for receptacles to use. I know there is PS Audio and thats it. Thanks
Post edited by rdb2001 on
  • FTGV
    FTGV Posts: 3,650
    edited April 2010
    Hubbell hospital grade 8200I 15A version or the 8300I for 20amp power cords.They may be PS Audio's source aswell.
  • ibewbrother
    ibewbrother Posts: 186
    edited April 2010
    As an electrician...I say any 20A spec (hospital) grade should be fine. If you are going to run designated neutrals, there are receptacles that have a mark on them to identify that, but for home use it isn't necessary. Basically I would say any 20A would be good enough..unless you wanted to go twist-lock or something like that.
    "Making life enjoyable through expensive electronics." BillD
    Pioneer Elite SC-57
    M70 series 2 mains
    CS2 center
    M40 surround
    M30 front height
    SVS PB 12 NSD
    Carver TFM-45 (mains)
    Carver A753x (center, surround)
    320GB PS3, 42" Panasonic G10,
    M60's as a Zone 2 off of the Pioneer in the living room
    R.I.P. Onkyo TX-NR807
    F1nut Posts: 51,788
    edited April 2010
    The PS Audio Premier takes it to a higher level.
  • tcrossma
    tcrossma Posts: 1,301
    edited April 2010
    I'm using some of of these and am quite happy with them.
    Speakers: Polk LSi15
    Amp: Pass Labs X-150
    CD/DVD Player: Classe CDP-10
    TT:Micro Seiki DD-35
    Cartridge:Denon DL-160
    Phono Pre:PS Audio GCPH
  • Midnite Mick
    Midnite Mick Posts: 1,591
    edited April 2010
    When I put my system back together I plan on using some ATL new cables on recommendation from my dealer.
    Good luck,
    Mike
    Modwright SWL 9.0 SE (6Sons Audio Thunderbird PC with Oyaide 004 terminations)
    Consonance cd120T
    Consonance Cyber 800 tube monoblocks (6Sons Audio Thunderbird PC's with Oyaide 004 terminations)
    Usher CP 6311
    Phillips Pronto TS1000 Universal Remote
  • rdb2001
    rdb2001 Posts: 791
    edited April 2010
    So there is a noticeble difference in the performance of your amps with these? I am running an adcom gfa 555 for two channel and sherwood newcastle a965 for hometheater( 2 channel is integrated in my home theater). Just want to makw sure I am getting the best sound out of both of them.
