Is this a common issue?
ok so every room i have attempted to place my subwoofer in i always have 2x the bass when i am standing, if i sit back down, it goes back to normal, is this a common issue and what can be done to correct it?
Post edited by yepimonfire on
  • rubin
    rubin Posts: 565
    edited April 2010
    Yes pretty well all rooms have dips & peaks in the bass region.Some fixes are diff. sub locations,room treatment(panels),dual subs.
  • danger boy
    danger boy Posts: 15,722
    edited April 2010
    that is common.. and none of us watch movies at home standing up.. so find the correct placement for your sub and dial it in.. and sit back and enjoy.
    PolkFest 2012, who's going>?
  • hearingimpared
    hearingimpared Posts: 21,136
    edited April 2010
    danger boy wrote: »
    Didn't candyliquor listen to his rig standing up?:rolleyes::D
  • bld
    bld Posts: 25
    edited April 2010
    Try raising your sub off the floor,I had the same problem and i mentioned to a high end ht installer and he gave me this advice,so i put it on a chair (with a padded seat) till i can make a proper stand for it.Doesn't hurt to try.
    nad t175 processor
    Sunfire TGA 7401 amp
    LSi15 front
    LSi center
    LSI 9 surround
    dual sunfire hrs 12 subs
    LG bd 390 blueray
    Sonos
    edited April 2010
    WELCOME TO CLUB POLK!
    Why don't you try the 'sub/dance'....put your sub in the position where you normally sit and then walk around the room listening for where you hear the LOUDEST and BEST quality bass--that's where your sub should BE. And also, as suggested above, you may want to decouple the sub from the floor.
    On another note if one can listen to a sub standing up what about those who use inversion boots?
    cnh
  • hearingimpared
    edited April 2010
    cnh wrote: »
    cnh
    Hey, aren't you supposed to be sleeping?:D
    edited April 2010
    Nah, it's only 11 PM here....I've never been an early sleeper...in fact I love the NIGHT! Ah, but the sunlight is so bright...thank god there's such a smog in China! Don't even have to worry about using SUN-BLOCK over here. lol
    cnh
  • hearingimpared
    edited April 2010
    cnh wrote: »
    cnh
    Admit it Bro, the vampire bite from here has taken you into the world of the undead! Hahaha!:eek::D
  • yepimonfire
    yepimonfire Posts: 256
    edited April 2010
    i figured out where the issue is originating, i have a small room, the area where the ceiling meets the wall is essentially a corner, therefore i have purchased bass traps and plan to place them in the corners and ceiling wall conjunctions.
    thanks for the help, and i already know these tricks, ive been an audiophile since the day i first heard a sound system. the three most important things on my list goes as food, sound, and girls lol.
