low bass output
Hello All,
Just got my new driver for my rti12's.Everything sounds great except for lowend bass.Have plenty of high current power.Am I just expecting to much from these things or what?
Parasound Avc-1800
Mains-Rti 12 -Parasound 1500a
Center-Csi5-Parasound 1000a
Rears-Rti 8-Parasound 750a
Sub SVS Ultra Tv 12
Diamondback and King Cobra IC's
AQ T4 SC
Sub SVS Ultra Tv 12
AQ T4 SC
Post edited by cnoat on
You will need to provide more details such as your equipment and setup.Speakers: SDA-1C (most all the goodies)
I am running an onkyo 898 for my pre.The bass management settings are really minimal.Just have large or small.The manual doesn't even tell me what the xover points are.
I have a pair of Parasound 1000's bridged to the front.
The 12's are being used for music.Parasound Avc-1800
Sub SVS Ultra Tv 12
AQ T4 SC -
try putting them closer to the wall behind them -- might help (might not)
-- wayne --Yamaha RX-V2700, EMI 711As (front), RCA K-16 (rear), Magnavox Console (Center & TV Stand), Sony SMP-N200 media streamer, Dual 1249 TT =--- Sharp Aquas 60" LCD tellie -
It helped in the sense I can hear it better,but it clouded it up.Parasound Avc-1800
Sub SVS Ultra Tv 12
AQ T4 SC -
do you have them canted in about 3 - 5 degrees towards your sweet spot?
I saw a subwoofer placement diagram once that suggeested if a front firing sub is perpendicular to the wall that the bass will reflect off the opposite wall and cancel itself out.
(see yamaha's YST-SW150 user's manual).
The same could be said for a 10/12 inch passive radiator - as we are still talking about 20 - 100 HZ freq. range
wayneYamaha RX-V2700, EMI 711As (front), RCA K-16 (rear), Magnavox Console (Center & TV Stand), Sony SMP-N200 media streamer, Dual 1249 TT =--- Sharp Aquas 60" LCD tellie -
Yes they are angled towards my listening position.
I am not using a sub for two channel mode.
Got the 12's cause I thought they would produce better.
I think I am expecting to much.
SteveParasound Avc-1800
Sub SVS Ultra Tv 12
AQ T4 SC -
Thanks eveyone.
I reversed the polarity just for kicks.Big improvement.
I don't really understand it but it worked like a charm.Thanks again
Sub SVS Ultra Tv 12
AQ T4 SC
