Signal Cable Digital Coax
acmf74
I'm trying to decide on a Digital Coax cable for my rig. My question is would I get more detail in the Silver Resolution line or would the the SPDI/F Digital Coax suffice?
From what devices?
Adcom GFR-700 AVR
Adcom GCD-600 CD player.
Polk LSi15 fronts.
Thanks! -
You should. I have this cable which beat out all that I tried but never tried a signal cable.
Can be had for less than $200 1 meter used.
http://www.audioadvisor.com/prodinfo.asp?number=KKD60Speakers: SDA-1C (most all the goodies)
I decided to go with the SPDI/F Digital Coax. I only listed to it for an hour. So far the clarity is great on it and I did notice some bass improvement. Nice product.
