sub set up for RM6750
chris chua
i just both the RM 6750. what is the proper way to set up the subs?
Post edited by chris chua on
Just to clarify, there is only one sub in the RM6750 right?
-JeffHT Rig
Receiver- Onkyo TX-SR806
Mains- Polk Audio Monitor 70
Center- Polk Audio CS2
Sub- Polk Audio PSW125
Blu-Ray- 80 GB PS3
2 CH rig (in progress)
In either case the best way would be to hook it up to the "Sub Out" on the back of the AVR (which ever one you may have) it should be purple in color and labled "Sub Out" or "Sub Preout" or something to that nature. Since the sub in the 6750 doesn't have an LFE in, you will need to get a sub cable and a Y adapter to hook it up properly. Hook one end of the sub cable to the previously mention hook up on the AVR and the to the Y adapter, then plug them into the Line In L/R on the back of the sub. There is also another way to do it where you hook it up to only one of the L/R inputs on the back of the sub using the sub cable and no Y adaptr, but I run my sub LFE and don't have much experience with the other way. I would wait for better advice from someone with experience and not take what I have to say as law. Good luck, and welcome to Club Polk.
-JeffHT Rig
Blu-Ray- 80 GB PS3
