muffled static
rocket
rocket Posts: 71
edited April 2010 in Vintage Speakers
I am getting a "bleeding off" noise of static occasionally from my sda-srs 2.3tl. played it in stereo this morning, and very little sound coming out. put in a new fuse, and was like brand new again. I noticed tonight it started to do this bleeding again, and even does it when the stereo system is shut off. (for about 5-6 seconds after shutdown. bad cap bleeding out? I don't know. any suggestions? I have rebuilt the boards over a yr ago, and they have been flawless. they have been subjected to high volumes, never a problem. HELP!:confused:
Post edited by rocket on
    F1nut Posts: 51,776
    edited April 2010
    New fuse? The 2.3TL's don't have a fuse.
    I'd have to say you have a problem with your amp, not the speakers.
  • rocket
    rocket Posts: 71
    edited April 2010
    the amp has a fuse, Jesse, and if it was the amp, why would the speaker still have this noise when amp is shut off?
  • concealer404
    concealer404 Posts: 7,440
    edited April 2010
    rocket wrote: »
    If the amp was shut off, the speakers wouldn't be making a noise. No signal.
    It's gotta be the amp.
    F1nut Posts: 51,776
    edited April 2010
    rocket wrote: »
    OK, that wasn't clear in your original post. Most likely a bad cap(s) in the amp.
    heiney9 Posts: 25,432
    edited April 2010
    What amp.............many better designs don't have any sort of muting or limiting circuit and the caps will drain and make some noise unless you turn your equipment off in the correct order.
    P.s. I will add if this just started then it most likely is a bad cap(s) somewhere. I had a similar issue in the soft start of a pre-amp. Once a few caps were replaced............just like new.
  • rocket
    rocket Posts: 71
    edited April 2010
    the amp is in being looked at-it is a mpa 3250 (monster power) thanx all, I believe it is the amp. these polks can take some serious power!
