Anybody use Sony CD-Rs for recording music?
Norm Apter
I've been a big fan of Verbatim CD-Rs for a while, however, Costco is currently running a sale on Sony CD-Rs: 100 packs for $11.49 each, so I just picked up a spindle.
Actually, Costco sells two items with similar but slightly different packaging: Sony CD-R and Sony CD-R Music. They appear to be exactly the same though, except the former are a few bucks cheaper so those are the ones I picked up. Should their be any difference for recording music purposes between the two? (both are listed as having a capacity of 700 MB and up to 80 minutes).
Furthermore, any opinions on reliablity for Sony CD-Rs...good, bad? (I can still return these, as I haven't opened them yet)
2 Ch.
Parasound Halo A23 Amp
Parasound Halo P3 Preamp
Parasound Halo T3 Tuner
Bada HD22SE tube CD Player
Magnum Dynalab Signal Sleuth
Magnum Dynalab ST-2 antenna
polkaudio Lsi9s (upgraded cross-overs)
MIT Shotgun S-3 Bi-wire Interface Speaker Cables
MIT Shotgun S-3 Interconnects (3)
IegO L70530 Power cords (3)
HT
Denon 2808ci AVR
polkaudio RTi A5s (fronts)
polkaudio RTi A1s (rears)
polkaudio Csi A6 (center)
Signal Cable Ultra Speaker Cables
Signal Cable Analog II Interconnects
HT
Denon 2808ci AVR
Post edited by Norm Apter on
I've used them before, and never had any problems.
I've never really done any extensive testing between different brands of CD-R's though.The nirvana inducer-
APC H10 Power Conditioner
Parasound Halo P5 preamp
Norm, the difference between an Audio CD-R and Data CD-R is that an Audio CD-R is coded making it compatible with stand alone recorders, but basically there's really no difference between the two.
I prefer the Verbatim discs also, but have used the Sony CD-Rs also without a problem. The Verbatim might be better as far as longevity, so if what you're putting on the disc is crucial, then these are probably a better choice. If you need the best possible blank media, then I'd recommend the MAM-A Gold Thermal discs. These are quite a bit pricier though.
Thanks for the explanation, Mike. I just use Winamp Media Player on my laptop for recording, so these should work just fine then.
I keep back up files of all music I record to CD-Rs on a separate 1TB hard drive so I should be OK with these. But after the sale ends I will probably go back to Verbatim. I've burned several hundred Verbatim CD-Rs with very, very few failures (I could probably count them on on hand).2 Ch.
HT
Denon 2808ci AVR
Signal Cable Analog II Interconnects -
I use the Sony Audio CD-R's in my Phillips stand alone. Almost nothing else works and the Sony's work great.SDA-1C (full mods)
Carver TFM-55
NAD 1130 Pre-amp
The Clamp
Nakamichi CR7 Cassette Deck
Cambridge Audio DACmagic Plus
ADC Soundshaper 3 EQ
Ben's IC's
Nitty Gritty 1.5FI RCM -
comfortablycurt wrote: »I've used them before, and never had any problems.
I'm with Curt on this.
I was a big fan of Maxell CD-R Pro's but I can't find em anymore!
Yamaha RX-A710 90Watt 7.1
Mains: RTi A1's Center: CS150 Sats: RT15i's Sub: Velodyne DPS-10
Music CD: Sony CDP-CE375 5 Disk
HD TV: Vizio 42" LCD 1080p E420VO
Blu-Ray: Sony BDP-S350
DVD: Sony DVP-NC665P 5 Disk
AV Rack: Sanus Euro EFAB-II Audio Base x2 EFAS-II Audio Expansion Shelf x4
Cables Used: Monster Cable HPD Sony HDMI DLCHE18W
Phones: Sennheiser HD280 Pro -
Same here for my Philips as well.Main System: Polk SDA SRS 1.2 Speakers, Sunfire Signature 600~two Amp, Carver C-16 Preamp, Carver TX-11b Tuner, Marantz 6350Q TT, Philips CDR-775 Recorder, Teac V-707RX Cassette Deck, Signal Cable Double Run Speaker Cable
Upstairs Den: Marantz 2325 Receiver, Marantz 5220 Cassette Deck, Marantz HD-880 Speakers, Marantz 6370Q TT
Exercise (Kabuki speaker) Room: Kenwood KR-9600 Receiver, Pioneer CS-99a Speakers, Sansui SP-X9000 Speakers (not pretty, but LOUD!
