My Current Setup - What Next?
SlackerCSB
My current setup:
(2) Monitor 70s Upfront
(1) CS2 Center
(2) Polk M10s Surround
(1) Elemental Designs A2-300 Subwoofer
(1) Onkyo HTRC160 Receiver
I'm really happy with my setup... but am always looking to upgrade. Where should I go from here - any of those components look weak?
Thanks!!
(1) CS2 Center
Thanks!!
Post edited by SlackerCSB on
You should go to the couch and enjoy, otherwise you will end up spending more and more money.
You have a good setup so there is no real need to upgrade. However, there is ALWAYS ways to spend money if you really want. So it is a matter of priorities. If you like your system as it is then spend your money on other things.
If you must upgrade, the monitor 70's do like external amplification. Unfortunately your AVR does not have pre-outs. -
maximillian wrote: »If you must upgrade, the monitor 70's do like external amplification. Unfortunately your AVR does not have pre-outs.
You hit the nail on the head: upgrade your AVR!
If you're happy with the sound from your Onkyo, maybe check out something from their Integra line.
Living Room: Receiver: Pioneer Elite SC-25 | Turntable: Technics SL-B200 | CD Player: Rotel RCD-955AX | Fronts: Polk RTiA3 | Center: Polk CSi A4 | Rears: Polk FXi3 | Sub: Velodyne DPS-10 | Cables: AudioQuest Type4 & TypeA
Office: Carver HR-742 | Speakers: RTi6 | Turntable: Numark 1600 -
Hello,
This link may help without spending money
http://www.polkaudio.com/forums/showthread.php?t=96827
