Don't you just hate it when....
wayne3burk
wayne3burk Posts: 939
edited April 2010 in Vintage Speakers
.... goodwill marks on speakers with a magic marker
-- wayne --
Yamaha RX-V2700, EMI 711As (front), RCA K-16 (rear), Magnavox Console (Center & TV Stand), Sony SMP-N200 media streamer, Dual 1249 TT =--- Sharp Aquas 60" LCD tellie
Post edited by wayne3burk on
  • wayne3burk
    edited April 2010
    i forgot to mention -- perfectly good speakers ;)
    -- wayne --
    I just got these this morning after i dropped my wife off at work
  • hearingimpared
    hearingimpared Posts: 21,136
    edited April 2010
    Bummer man. But they are practically giving good stuff away so they get leeway in that respect. Right?
  • packetjones
    packetjones Posts: 1,059
    edited April 2010
    That is terrible. All it takes is a small peice of paper or a label maker. The goodwill in my area has a pricing gun that they use. I would be very upset if they wrote on speakers that i wanted to purchase.
    They look nice. You said they were working fine? What are they?
    Front - RTiA5's
    Rear - RTiA3's
    Center - CSiA4
    Sub - PSW110
  • Knucklehead
    Knucklehead Posts: 3,602
    edited April 2010
    Yeah thats crappy that they do that...I found "dissolvet" will get it right off and not damage the finish.
    Polk Audio Surround Bar 360
    Mirage PS-12
    LG BDP-550
    Motorola HD FIOS DVR
    Panasonic 42" Plasma
    XBOX 360[/SIZE]
    Office stuff
    Allied 395 receiver
    Pioneer CDP PD-M430
    RT8t's & Wharfedale Diamond II's[/SIZE]
    Life is one grand, sweet song, so start the music. ~Ronald Reagan
  • wayne3burk
    edited April 2010
    Monitor 10s - $20 for the pair. They sound great
    -- wayne --
    billbillw Posts: 7,486
    edited April 2010
    If its vinyl, you should be able to remove it with nail polish remover.
  • ShinAce
    ShinAce Posts: 1,194
    edited April 2010
    Rubbing alcohol might get it off.
    Back in the day we used to write prices on tin cans with permanent marker. We took it off(repriced) by wetting the old writing with new permanent marker and then quickly wiping it off. This would usually get 90% of it off but depends on the surface.
    p.s. google is your friend...;)
  • inspiredsports
    inspiredsports Posts: 5,502
    edited April 2010
    wayne3burk wrote: »
    -- wayne --
    That's a great price even if the vinyl was stripped off all the way down to raw particleboard :D
    Hang in there, you'll find a way from the suggestions above to restore them as if they never touched them with a marker.
    Conrad Johnson PV-5 w/mods
    MF x-DAC V8, HAInfo NG27
    NAD SS rigs w/mods
    GIK panels
    Tony M Posts: 11,589
    edited April 2010
    billbillw wrote: »
    Yep, we've used that for years.
  • maxilla
    maxilla Posts: 41
    edited April 2010
    Yes, alcohol will clean that up.
  • Schurkey
    Schurkey Posts: 2,122
    edited April 2010
    maxilla wrote: »
    Drink enough and you won't care that the speakers are defaced???
  • george daniel
    george daniel Posts: 12,096
    edited April 2010
    Are those AR 4Ax's in the pic?
  • wayne3burk
    edited April 2010
    Nope -- those ones riding piggy-back are my $15 Dynaco A25s.
    I already kicked them upstairs in my office/den with my Yamaha CA-610 / CT-610 near field 2 channel system.
    :) wayne :(
    edited April 2010
    There has to be a Chemist among us who knows of a solvent that will remove permanent marker ink? No?
    Of course this has NEVER been a problem for me because there is NEVER anything worth buying at my GW--in the gear sense. WHERE do you guys find this stuff?
    Would you like some GPX speakers?? Plastic boxes..only 5 dollars a pair!! lol
    cnh
    edited April 2010
    cnh wrote: »
    Like I said, nail polish remover, ie: Acetone. It will take off sharpie every time.
  • RuSsMaN
    RuSsMaN Posts: 17,986
    edited April 2010
    I have to ask, what's the spool on top of the TV?
  • wayne3burk
    edited April 2010
    RuSsMaN wrote: »
    lol -- thats my center channel speaker
    An RCA Victor KS-16 satellite. It has a 6x9 mid and a 3 inch tweeter. I have a pair of them, just can't find any corresponding RCA-Victor PS-16 (tube amp phono cabinet with built in woofer).
    -- wayne --
    p.s -- it's cylindrical and laying on it's side with the speakers pointing about 3 degrees down from horizontal
    mhardy6647 Posts: 34,938
    edited April 2010
    I would probably try (in order of aggressiveness):
    GooGone
    alcohol (either ethyl or isopropyl)
    acetone
    Goof Off (i.e., xylene)
    Naptha (lighter fluid)
    gasoline
    gasoline + match
    particle beam
    fission explosives
    fusion explosives
  • ShinAce
    edited April 2010
    GooGone
    acetone
    gasoline
    gasoline + match
    particle beam
    fission explosives
    fusion explosives
    Where's the love for the holy water?
    edited April 2010
    I was going to start my list with mother's spit, but truth be told, while it is a miracle solvent, it likely won't remove permanent marker :-)
    Holy Water... hmm...
    and, in all seriousness, Goo Gone is pretty handy stuff.
  • wayne3burk
    edited April 2010
    Goo Gone + elbow grease....
    .... now they sound like $200 speakers :)
    -- wayne --
  • Bobsama
    Bobsama Posts: 526
    edited April 2010
    How about sandpaper, wood stain, and a sealant?
    polkaudio Monitor 5 Series II
    polkaudio SDA-1 (with the SL1000)
    TEAC AG-H300 MK III stereo receiver
    beyerdynamic DT-880 Premium (600 Ω) headphones
    SENNHEISER HD-555 headphones
    Little Dot MK IV tube headphone amp
    Little Dot DAC_I balanced D/A converter
  • wayne3burk
    edited April 2010
    +1 on the Goo Gone - It worked just fine - Goo Gone is your friend
    -- wayne --
    edited April 2010
    cool enough. Glad you didn't need to resort to the nuclear option. You'd have some 'splainin' to do.
  • FiveORacing
    FiveORacing Posts: 105
    edited April 2010
    "10" was a good mark to put on it though!
    I remember someone wrote on the dry eraser board at work with a permanent marker. They tried everything from Goo Gone to SprayNine and it wouldn't come off. I was messing around and found that using a fresh DRY Eraser Marker (not red though) and scribbling over the marks reactivated the ink and you could quickly wipe it off with a windex soaked cloth.
    It also works on other surfaces with permanent marker on them.
  • wayne3burk
    edited April 2010
    I had the photon torpedoes charged and ready to fire
    edited April 2010
    :-) Good tip.
    I learned that trick nearly 2 decades ago from the CEO of the company I was working for at the time(!?!).
  • vtomike
    vtomike Posts: 3
    edited April 2010
    Use Magic Eraser. It will come off no problem. Works great on silver faced gear as well.
  • hearingimpared
    edited April 2010
    Welcome to Club Polk vtomike!!! Nice first post!
  • wayne3burk
    edited April 2010
    vtomike wrote: »
    I'll try the Magic Eraser on my SAE Two P-10 amp. That $30 thing has got to go.
    Thanks,
    Wayne
