Bi wiring sda-srs
313GUY
313GUY Posts: 5
Long time lurker, first time caller.
I have a nice set of SDA-SRS's and am thinking about trying bi-wiring. I am looking at a used Outlaw 1050, which will be my first HT receiver if I get it. My question is, can I use it as a stereo receiver and bi wire 2 of its channels to my Polks, or is this is crazy idea? Are there risks involved to either of the components if I do this? It seems like such a waste to have a 6 amps in the receiver and only use 2 of them when they are hooked to speakers that are "bi-ampable". By the way, I have never bi-amped them with anything else, so they have been "jumpered" since I have owned them.
Post edited by 313GUY on
  • ben62670
    ben62670 Posts: 15,969
    edited April 2010
    Welcome to Club Polk. You would be much better off buying an amp than a receiver. BiWiring is way over rated. You would be better off getting a single high quality pair of cables than 2 sets.
    Ben
    Ben
  • 313GUY
    313GUY Posts: 5
    edited April 2010
    Ben
    Thanks for the reply and welcome. My reason for trying this is mainly to exploit more of the 6 amps in the receiver, though. I am not totally versed in what bi-wiring does for me anyway. Does it separate the signals to high and low drivers? :confused:
    I am using the SDA cable between the speakers, by the way. Does this complicate it further? I have been using a variety of vintage receivers and integrateds in the past, and was looking for a more permanent solution.
  • vc69
    vc69 Posts: 2,500
    edited April 2010
    I have to agree with Ben. Though I have no experience with SDA's I do know that most multi-channel receivers share a common power supply. Therefore, bi-amping is a moot endeavor. You would need separate amps and that would seem to complicate the common ground issue. Perhaps others will chime in with more experience, but a good amp and a good set of speaker wires would probably yield much better results.
    -Kevin
    2 Channel:
    Oppo BDP-83 SE
    Squeezebox Touch
    Muscial Fidelity M1 DAC
    VTL 2.5
    McIntosh 2205 (refurbed)
    B&W 801's
    Transparent IC's
  • 313GUY
    313GUY Posts: 5
    edited April 2010
    My understanding of the Outlaw receiver is that it has 6 discrete amps onboard. Can anyone chime in on the truth of this claim?
    F1nut Posts: 52,022
    edited April 2010
    You mention bi-wire and then bi-amp...huge difference, so which is it?
  • 313GUY
    313GUY Posts: 5
    edited April 2010
    I am obviously a newbie when it comes to the nomenclature. What I want to do is hook wires to both sets of binding posts on each of two stereo speakers. The other ends of these 4 wires will terminate at the speaker outputs of a single multi channel home theater receiver which advertises 6 amplifiers. I do not know if this is bi-wiring or bi-amping or both, because I admit I do not understand the difference and confess I was not aware of on previously. If you would be kind enough to explain the difference and how each relates to what I am considering, it would be appreciated.
  • 313GUY
    313GUY Posts: 5
    edited April 2010
    Ok, I tried to look up the difference between bi amp and bi-wire and have gone from ignorant to completely confrazzled. (Yes , I made that work up, but my spell checker now accepts it.) It seems what I am considering is a combination of both methods.
    F1nut Posts: 52,022
    edited April 2010
    Some reading material, so that I don't have to type it all. :)
    http://en.wikipedia.org/wiki/Bi-wiring
    http://en.wikipedia.org/wiki/Bi-amping
    http://www.oregondv.com/Audio_FAQ_Bi-Wire_Bi-amp%20.htm
    http://stereos.about.com/od/optimizingperformance/p/bi-wire.htm
    Personally, bi-wiring is a waste. You are much better off replacing the factory jumpers with high quailty wire.
    Bi-amping with other channels in your AVR isn't really bi-amping, more like ghetto bi-amping. The fact that you have SDA's complicates the matter considerably.
  • cstmar01
    cstmar01 Posts: 4,424
    edited April 2010
    loving that term.....and good advice! and links!
