OWM5 Wall Mounting
Has anyone had success using a particular articulating wall mount for the OWM5? I will be using the OWM5 as side surrounds and will need to angle them down to the sweet spot.
TIA,
kb
TIA,
kb
Post edited by kb4all on
Angling is built into the speaker case mounting provisions by design. If the particular built in angle doesn't work for you then you have to get creative.Parasound C1, T3, HCA-3500, HCA-2205A, P/DD1550, Pioneer DV-79avi, Oppo BDP-83, WD Media Server W/HDD,
Dynaudio Contour 3.3, Dynaudio Contour T2.1, Polk OWM3, Polk DSW micropro 1000 (x2),
Pioneer Kuro 50" Plasma, Phillips Pronto Control w/Niles HT-MSU. -
I'm using them with articulating wall mounts:) The center of the OWM5 has a threaded hole dead center to allow for using mounts if need be. You just need to make sure the mount(and your wall) can handle the speakers weight. I'm using the generic articulating mounts that only have two screws holding the base, and they are mounted to drywall. I've had absolutely no problems myself. The OWM5 is pretty lightweight as far as speakers go, so there should be plenty of mounts that could handle them.Sony 40" LCD
Sony DVPCX995V
Sony PS3(games/media server)
Sony PS2
WD TV Live with 3TB
Sanyo VCR
Marantz SR6003
Polk 11T(xover/RDO)
RM20 5 pack
OWM 5
DUAL Micro Pro 1000
Combastard Cable
Harmony One
When rapture comes, can I have your car?
