DR.SPEC!! SVS tube or cube same same??
I just want to know, is the new pb1 the same as the 20-39 pci, for the first time ever, when i mentioned to my wife about getting a SVS she said that has carpet right?? she likes the wood or atleast a box, so is the pb1 same low bass as the cylinder subs??
MY HT RIG:
Sherwood p-965
Sherwood sd871 dvd
Rotel 1075 amp x5
LSI15 mains
LsiC center
LSIfx surround backs
Lsi7 side surrounds
SVS pb12/plus2
2 Channel Rig:
nad 1020 Pre-amp
Rotel 1080 stereo amp
Polk sda 2B
kenwood grunt Tuner
realistic lab 450 TT
Signal cable IC
Sherwood p-965
Sherwood sd871 dvd
Rotel 1075 amp x5
LSI15 mains
LsiC center
Lsi7 side surrounds
SVS pb12/plus2
2 Channel Rig:
nad 1020 Pre-amp
Polk sda 2B
kenwood grunt Tuner
Signal cable IC
Post edited by faster100 on
Now we know what the recent rash of fund-raising was about...
faster, the good Doctor is out right now.
I can say that he is planning to give the new pb2 a spin and thinks it can improve on his cylinder's performance. I don't think he would say the same about the pb1... at least he never has that I know of...
But hey, I'm only an intern...More later,
Tour...
Vox Copuli
The PB1 goes down to 25hz, and its not wood. Its like a fiberglassish type mess. Not exact fiberglass. Let me put it this way....its like...impervious to scratches. Well, the Pb1 goes down to 25hz, if im not mistaken if you plug the port it goes down to 20hz. But who would want to flood the driver?- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
So are we saying yeah or na?? On the pb1, I can't drop 1200 on a sub for the pb2, out of the question. its either the 20-39 pci or the pb1....... i have a Micro room for now so i don't need earth cracking bass for awhile i just want more then i have..MY HT RIG:
Sherwood p-965
Sherwood sd871 dvd
Rotel 1075 amp x5
LSI15 mains
LsiC center
Lsi7 side surrounds
SVS pb12/plus2
2 Channel Rig:
nad 1020 Pre-amp
Polk sda 2B
kenwood grunt Tuner
Signal cable IC -
faster,
I believe Tom at SVS has made the statement that the Pb1 has the same output as their small cylinder sub. There may be more info on their website.
Danny -
Where is the doc anyway?"Its worked so far but we're not out yet."
"Hey big man let me hold a dollar" -
I just e-mailed svs, Doc can get back with me when ever he shows up..MY HT RIG:
Sherwood p-965
Sherwood sd871 dvd
Rotel 1075 amp x5
LSI15 mains
LsiC center
Lsi7 side surrounds
SVS pb12/plus2
2 Channel Rig:
nad 1020 Pre-amp
Polk sda 2B
kenwood grunt Tuner
Signal cable IC -
Dr. stated that it was the same essentially just in box form for those who wanted a traditional design subwoofer.CTC BBQ Amplifier, Sonic Frontiers Line3 Pre-Amplifier and Wadia 581 SACD player. Speakers? Always changing but for now, Mission Argonauts I picked up for $50 bucks, mint.
From the perspective of the physics of a subwoofer, it *shouldn't* matter. All the driver cares about is the volume of air behind it and how hard/easy it is to move it. It does NOT care what shape that air takes. Assuming there are no design problems in either the cylinder or box, such as a mislocated or missized port, then the same volume, driver, port(s) etc should give you essentially the same result. If SVS says the difference is appearance only, that very well *could* be true... you need only decide if you believe SVS. I'd lean towards believing them. They have too much to lose to misrepresent their products.
I never read anything about it, so i wasnt saying they were wrong or right, I wanted Specs advice i guess.. even though he hasn't tried one yet i assume, I have already spoke with Tom at SV and he had given me all the info i need, Thanks
I will be getting the pb1 after i sell this 404 and save the rest, Thanks everyoneMY HT RIG:
Sherwood p-965
Sherwood sd871 dvd
Rotel 1075 amp x5
LSI15 mains
LsiC center
Lsi7 side surrounds
SVS pb12/plus2
2 Channel Rig:
nad 1020 Pre-amp
Polk sda 2B
kenwood grunt Tuner
Signal cable IC -
Good show faster... was going to recommend you call Tom. I think you have chosen well.
Sid,
The PB1 is tuned to 22 Hz, that's the low end rating +/- 3 db.More later,
Tour...
Vox Copuli
The 20-39PCi and the PB-1 will perform nearly identically from about 22-23hz and up under that and the 20-39PCi will have a very slight edge.
In your room, both of these options will extend down to the 16-18hz range, providing a clean 112-118dBs of output.(very low and very loud). Which receiver are you using in your system? The smaller the room, the deeper a given subwoofer will extend. This is due to the acoustical phenomenon commonly referred to as *room gain*. Which also explains why cars can reach such deep/loud bass with a single 10 driver..:)
The 404 is a ported unit tuned fairly high in the 35-40hz range I believe. With a relatively small enclosure and a 10 driver, it is going to be hard pressed to really energize the room with low clean bass. I am very confident youd find any fo the SVs to be a huge improvement esp in the 16-32hz octave.
Tom V.
SVS
Straight from Tom @ SVSMY HT RIG:
Sherwood p-965
Sherwood sd871 dvd
Rotel 1075 amp x5
LSI15 mains
LsiC center
Lsi7 side surrounds
SVS pb12/plus2
2 Channel Rig:
nad 1020 Pre-amp
Polk sda 2B
kenwood grunt Tuner
Signal cable IC -
bumpMY HT RIG:
Sherwood p-965
Sherwood sd871 dvd
Rotel 1075 amp x5
LSI15 mains
LsiC center
Lsi7 side surrounds
SVS pb12/plus2
2 Channel Rig:
nad 1020 Pre-amp
Polk sda 2B
kenwood grunt Tuner
Signal cable IC -
Sorry about the slight delay, Faster, I was out of town for a few days.
The PB1-ISD is a virtual sonic clone of the 25-31PCi with the optional 22 Hz port installed. This mod is free and popular with the 25-31 owners. This model is affectionately known as the "22-31PCi" even though no official model designation exists for this particular sub.
The 20-39PCi will dig a bit deeper than the PB1-ISD, but it might not be noticeable with most program material.
The PB1-ISD is a wooden enclosure, but the finish is that tough pebble black texture.
I think you will find either the 20-39PCi, the 25-31PCi, the "22-31PCi", or the PB1-ISD all to be a huge improvement over the 404 in terms of clean output, and deeper extension.
Doc"What we do in life echoes in eternity"
SVS -
Sounds good to me, Thanks again as alwaysMY HT RIG:
Sherwood p-965
Sherwood sd871 dvd
Rotel 1075 amp x5
LSI15 mains
LsiC center
Lsi7 side surrounds
SVS pb12/plus2
2 Channel Rig:
nad 1020 Pre-amp
Polk sda 2B
kenwood grunt Tuner
Signal cable IC
