the sump pump died
goingganzo
goingganzo Posts: 2,793
this realey sucked but let me start a new remodleing project. you know the square box with the black tile on it next to the front couch holds the sump. now the box is gone and i am going to extend the platform in the shape of the box and put a chair on it. and i will have more room to seat peeps.
  • Ron-P
    Ron-P Posts: 8,520
    edited May 2003
    Word!
    If...
    Ron loves a film = don't even rent.
  • goingganzo
    edited May 2003
    i finaley got the sump working and not leaking. all i have left is to put up a piece of drywall and buld a extenshion for the platform.
    this is a pic of the old cover setting on the new base. but the new cover will sit flush. i havent decided what to use.
    F1nut Posts: 51,683
    edited May 2003
    So, what did you have to do, rip out part of the wall to fix the sump pump or was that from water damage?
  • goingganzo
    edited May 2003
    actuley i riped out a box i bult around the sump that i never liked. the pump died so i had to get a new one and had to refit the end so i figured to just fix what i hated.
    this is a pic from befor you can see the diferance.
    F1nut Posts: 51,683
    edited May 2003
    Ok, I got it. Yeah, nice room and I can see the advantage of flush mounting the new cover.
  • goingganzo
    edited May 2003
    tomarrow i will be getting the lumber and drydall to fix the hole and patch the other hole where the old sub was.
    ps thanks for the coments.
