Best way to transport SDA SRS Big Boys
selectsc
selectsc Posts: 14
edited April 2010 in Speakers
Thanks everyone for your feedback / insights on my previous thread! If I remember correctly a Driver or the Passive Radiator should be removed prior to transporting to prevent the Drivers from locking up. Any opinions on if that's necessary and if so which ones / how many? Long trip to pick these up. Thanks, Sandy. Leaving tomorrow!
Post edited by selectsc on
    nooshinjohn Posts: 25,906
    edited April 2010
    As I stated in your prior thread, the best way is to lay them on their backs with all drivers and passives in place. There will be less momement of the drivers this way, and that momement will be properly controlled.
  • selectsc
    selectsc Posts: 14
    edited April 2010
    Thanks John...missed your response.
  • comfortablycurt
    comfortablycurt Posts: 6,745
    edited April 2010
    FWIW, It'd be best to remove each driver and pack them individually.
    The nirvana inducer-
    APC H10 Power Conditioner
    Parasound Halo P5 preamp
  • hearingimpared
    hearingimpared Posts: 21,136
    edited April 2010
    Removing the drivers is an excellent idea.
    I must tell you though, I picked up my 1.2TLs from a guy in Medford Mass which is just north of Boston and drove them all the way back to South Philly. The SUV we had would only allow us to place them on their sides, face-to-face. I kept my hands on them the whole time so they wouldn't move around or bounce too much. I have had no trouble with the magnets shifting or locking up. I guess I'm just lucky.
    Oh and BTW, when we moved them from South Philly to Delaware where I live now, we covered them with moving blanket, stood them upright and tied them tightly to the rails inside the rental truck. Still no problems.
    F1nut Posts: 51,738
    edited April 2010
    Removing the drivers is a really bad idea........seriously bad idea.
    John stated the correct way, "the best way is to lay them on their backs with all drivers and passives in place. There will be less momement of the drivers this way, and that momement will be properly controlled."
  • vmaxer
    vmaxer Posts: 5,120
    edited April 2010
    Did you get the ones in Fort Walton Beach??
    Pio Elete Pro 520
    Panamax 5400-EX
    Sunfire TGP 5
    PS Audio GCPH phono pre
    Sunfire CG 200 X 5
    Sunfire CG Sig 405 X 5
    OPPO BDP-83 SE
    Ctr CS1000p
    Sur - FX1000 x 4
    SUB - SVS PB2-Plus
    Workkout room:
    Onkyo TX-DS898
    GFA 555
    Yamaha DVD-S1800BL/SACD
    Ft - SDA 1C
    Not being used:
    RTi 38's -4
    RT55i's - 2
    LSI 15's
    CSi40
    PSW 404
  • danger boy
    danger boy Posts: 15,722
    edited April 2010
    on their back with the drivers and passive in place. i've moved a pair of SRS's twice in the back of a SUV with no problems. I put a mattress down first though.. or a thick heavy piece of foam will work too. place another piece of foam between the speakers to they don't knock into each other.
    PolkFest 2012, who's going>?
  • hearingimpared
    edited April 2010
    Jess, just curious as to why it is a bad idea. I would think if you could keep the drivers separate and safe it would be a good thing. What am I missing here?
    F1nut Posts: 51,738
    edited April 2010
    Where are you going to put 16 drivers and 2 large PR's that is safer than screwed into the cabinet? Not to mention the potential risk of damage caused by getting a screw driver close to the surrounds.
    Flat on their backs the drivers will move up and down as the vehicle rolls down the road, which is how they would normally move standing up, in and out. In addition, the natural damping from the sealed cabinet will not let them travel too far one way or the other.
