Phono inputs on new Marantz reciever?
Dabutcher
Dabutcher Posts: 2,607
edited April 2010 in 2 Channel Audio
My tt works fine on my old Yamaha reciever. I cannot get it to work with new Marantz? There are no phono inputs,but I thought I could use the auxilary spots? Do I need a phono preamp? thanks,Darryl
Post edited by Dabutcher on
  • Erik Tracy
    Erik Tracy Posts: 4,673
    edited April 2010
    Dabutcher wrote: »
    You'll need an external phono preamp to connect to the aux inputs on your Marantz.
    These can be found for less than $100 or as much as $1000 (or more) - let your wallet decide what you can afford....welcome to the upgrade club! :D
  • doctor r
    doctor r Posts: 837
    edited April 2010
    Aux Inputs are designed for 1 volt line level input. Output from a cartridge (MM) is 3-5 millivolts (MC even lower). In addition to the amplicfication that is required an equilization curve to match the RIAA standard is needed to be included in the preamp. At the Axpona Show I saw a nice new unit offered by NERVE AUDIO for about $100. Google their name and check it out.
    Rick
    integrated w/DAC module Gryphon Diablo 300
    server Wolf Alpha 3SX
    phono pre Dynamic Sounds Associates Phono II
    turntable/tonearms Origin Live Sovereign Mk3 dual arm, Origin Live Enterprise Mk4, Origin Live Illustrious Mk3c
    cartridges Miyajima Madake, Ortofon Windfeld Ti, Ortofon
    speakers Rockport Mira II
    cables Synergistic Research Cables, Gryphon VPI XLR, Sablon 2020 USB
    rack Adona Eris 6dw
    ultrasonic cleaner Degritter
  • comfortablycurt
    comfortablycurt Posts: 6,745
    edited April 2010
    ^^What they said^^
    You need a phono preamp.
    The nirvana inducer-
    APC H10 Power Conditioner
    Parasound Halo P5 preamp
