onkyo overheating...
  • NewHTguy
    NewHTguy Posts: 584
    edited April 2010
    My 875 gets really hot (too hot to touch) even with a two channel amp powering my fronts. However, I have never had it go in protect mode. Mine is not enclosed and I do not use a fan. However, if it were in a cabinet I would definitely use a fan.
    MAIN: Polk Lsi9s; Polk PSW505; Lsic (in box); Onkyo SR-875; Parasound 2250; Cambridge Audio 740C; LG BD370
    OFFICE: Polk Lsi7; REL T3; HK 3490; CA 840W; Onkyo C-S5VL
    BENCHED: CS20; OWM3s
  • lanchile
    lanchile Posts: 560
    edited April 2010
    Ugh....if it needs a fan, I want no parts of it.
    Well said! A well design amp will never need a fan to cool off. No matter how quiet is the fan, you will always hear some noise coming from it (unless it is unplugged lol) . People should listen to music, NOT the amp(transformers or fans)!!!;)
    Make it simple...Make it better!
    F1nut Posts: 51,778
    edited April 2010
    Let me add to this discussion by saying that just because an AVR or amp (there is a huge difference) gets hot is no reason to worry or not purchase the piece. I get the impression that some think if the piece isn't cool or slighty warm that there is a problem. Well, there isn't. Now, if an AVR or amp goes into protection because of heat issues, then you can worry.
  • wutadumsn23
    wutadumsn23 Posts: 3,702
    edited April 2010
    Well said Jesse, I agree 100%. I have an Onkyo and have had them as long as I can remember. Yes they are space heaters, esp the back right corner, but well ventilated there is no need for a fan at all. It may help with piece of mind, but is on no way a requirement. I have pushed my 806 for hours at moderate levels playing Blu Ray's, COD on the PS3, and listening to music and while it does get pretty darn hot, I have had that thing for almost 2 years now and not a single ssue (knocks on wood) Onkyo makes some damn fine AVR's and when it comes time to upgrade, Onkyo will be on the top of my list.
    -Jeff
    HT Rig
    Receiver- Onkyo TX-SR806
    Mains- Polk Audio Monitor 70
    Center- Polk Audio CS2
    Surrounds- Polk Audio TSi 500's :D
    Sub- Polk Audio PSW125
    Blu-Ray- 80 GB PS3
    2 CH rig (in progress)
    It's not that I'm insensitive, I just don't care.. :D
  • kuntasensei
    kuntasensei Posts: 3,263
    edited April 2010
    Are you using external amps, Kunta? If so, that would definitely help the Onkyo to run a lot cooler.
    Nope. Driving all 9 channels off of the 1007. Nary a blip. I ran a 7.1 setup off of a 705 before that, and though it got warm, it never got hot enough to cause any issues... and I never once heard its fans kick on.
    Equipment list:
    Onkyo TX-NR3010 9.2 AVR
    Emotiva XPA-3 amp
    Oppo BDP-93 Blu-ray player
    Epson 8500UB 1080p projector
