Pioneer VSX-1010ah-k to power RTi-A1 and CsiA4??
diggumvt04
diggumvt04 Posts: 6
I just got started building my HT. Im fairly new to this so any help is appreciated. I got the RTi-A1 bookshelf's and the CSi-A4 cc powered with a Pioneer VSX-1019ah-k. I'm running 12 ga speaker wire 9-12 ft/ea. My question is... 1) this amp should def be enough to power these speakers right?
and 2) Is it normal that I have the volume up to about -50 db before it reaches low listening levels, -40 avg levels and -20 somewhat loud.
My concern is that it just seems it takes quite a bit before I reach full sound, I'm not trying to put consistent strain on my av rec.
Any ideas on bi-amping these speakers? Thanks for any input and pardon the newbiness :) Polk rocks.
  • flyfisher
    flyfisher Posts: 220
    edited April 2010
    Welcome to club Polk.
    I had that receiver and it should be fine for those speakers.Have you ran mcacc yet?And as for Bi-amping those speakers,some people will will say its a waste of time and wire,then again if you have both,give it a try.let your ears be the judge.
    Anthony
    Living Room Monitor 60's*CS2*FXi A6's*VSX 21txh*BD-P1590
    Spare Room RTi A7*CSi A6*FXi A4's*Epik Legend*BDP-05fd*DVL-919 Laserdisc/DVD player
  • diggumvt04
    diggumvt04 Posts: 6
    edited April 2010
    Thanks. No I haven't run mcacc yet, I'm waiting to get the speakers settled in their final location before that. I will probably give the bi-amp a go, see if I get any different / better results. So you think listening in the -40 - -20db range is cool? Not too much strain on the rec. Just seems like a little much.
    Derek
  • flyfisher
    edited April 2010
    Well what kind of source are you listening to?For instance we have satellite.when i flip through channels,some will be lower and some will be higher.
    Also,make sure you have checked the speakers are in the proper terminals + and -.Not saying you don't know what your doing,but always double check.
    Keep us posted.
    Anthony
    edited April 2010
    +1, those Rti bookshelves are fairly efficient and the mid-line Pioneer should be able to handle them. The fact that you have to turn up the dial more than what seems normal to you has little to do with the Pioneer's power. Most volume dials, these days are not linear...in other words the volume increases much more quickly as you get to the higher end than it does on the lower end. In the old days....you turned the volume knob and it responded in a manner that was even from high to low. Those days are 'gone'.
    cnh
  • wutadumsn23
    wutadumsn23 Posts: 3,702
    edited April 2010
    You will be fine with that AVR, it doesn't have pre outs for adding an external amp down the road, but it should do a fine job just the same. Welcome to Club Polk.
    -Jeff
    HT Rig
    Receiver- Onkyo TX-SR806
    Mains- Polk Audio Monitor 70
    Center- Polk Audio CS2
    Surrounds- Polk Audio TSi 500's :D
    Sub- Polk Audio PSW125
    Blu-Ray- 80 GB PS3
    2 CH rig (in progress)
    It's not that I'm insensitive, I just don't care.. :D
  • diggumvt04
    diggumvt04 Posts: 6
    edited April 2010
    Thanks for the replies. Anthony - source is antenna w/ optical audio out. I have hooked up the Ipod and do notice an increase in volume given the same decibel range compared to TV. Have double checked the hook up (yes, can never hurt). I think I should be good.
    cnh - good point on the linearity,that gives a little more piece of mind.
    Jeff - true about the pre outs for future system - that was one (mild) concern.
    Any suggestions on a sub? or surrounds - are the Fxi a4's worth it?
  • flyfisher
    edited April 2010
    For the sub,the PSW505 is the best bang for the buck.Most people on here would recommend that.Newegg has em for $249 free shipping
    For the surrounds,I think either the fxi a4's or a6s will be fine.Make sure you check out Polk direct on Ebay for the surrounds and the psw505.
    Anthony
  • wutadumsn23
    edited April 2010
    +1 on the 505, for what you can get it for these days, it is hard to beat for an entry level sub. FYI, Newegg is running a special on the 505 that ends today (the 19th) for $20 off the 505, promo code EMCYRZP64. You have to sign up for a Newegg account, but it is free and well worth the couple minutes it will take you to save the extra $20.
    -Jeff
    HT Rig
    Blu-Ray- 80 GB PS3
  • diggumvt04
    diggumvt04 Posts: 6
    edited April 2010
    Thanks for input and heads up! Ill check that one out.
    edited April 2010
    Rti-A3s are on the short list for a second system when I return...along with a nice integrated!
    cnh
