question bout upgrading
would stepping up to lsi9 and lsic center be a improvement over my rti8 and csi5 setup? mostly for movies and concerts and little bit of music
front: rti8
center: csi5
surround: fxi3
sub: eD a2-300
receiver: onkyo 805
ps3
center: csi5
surround: fxi3
sub: eD a2-300
receiver: onkyo 805
ps3
Post edited by AGUERRA on
Yes, but you'd be entering a whole new world. Make sure you know what you're getting into.
it would..but i've always been led to believe that the LSi series do better for music.. and the RTi line is better for home theater.
stepping up to the LSi line you're looking at... you may have to add additional amps to your system.. they require more high current to run them... running them off most standard receivers is not the best idea.. esp if pushed.. it may fry your receiver.
so unless you got deep pockets.. i would stay with the RTi line.
PolkFest 2012, who's going>?
thanks for the advice. i'll do a bit more searching into what it takes to run them. i just love the look of them, but they way they sound is whats important.front: rti8
center: csi5
surround: fxi3
sub: eD a2-300
receiver: onkyo 805
ps3 -
sounds like a plan.. yeah at the very least if your recevier has pre amp outs.. all you would then need is a 5 channel amp that can run 4ohm speakers and you would be good to go.
these forums are evil cause all you do is read and look at new stuff and start asking and saying what if i had this or if i had that and bam the upgrade bug bites you.front: rti8
center: csi5
surround: fxi3
sub: eD a2-300
receiver: onkyo 805
ps3 -
Yeah I've been bitten so many times it's like I have fleas.:)Analog Source: Rega P3-24 Exact 2 w/GT delrin platter & Neo TT-PSU Digital Source: Lumin U2 w/Roon (NUC) DAC:T+A DAC 200 Phono Preamp: Rega Aria MK3 Preamp: Rogue RP-7 Amp: Infigo Method 6 Speakers: Joseph Audio Perspective 2, Audio Physic Tempo Plus Cables: Cardas Clear Reflection SC/IC, Shunyata PCs Misc: Shunyata Hydra Delta D6, VTI rack, GIK acoustic panels
LOL phip, Al (dangey boy) is spot on with this one. If you start looking into the LSi series, start looking at amps too, an AVR just won't do them justice. Your 805 is one of the better AVR's Onkyo has turned out over the past few years, and it has pre outs for adding an external amp, so you are good to go there.
-JeffHT Rig
Receiver- Onkyo TX-SR806
Mains- Polk Audio Monitor 70
Center- Polk Audio CS2
Sub- Polk Audio PSW125
Blu-Ray- 80 GB PS3
2 CH rig (in progress)
